Steam and Condensate
• Heat Loss and Insulation
Steam and condensate pipes - heat loss uninsulated and insulated pipes, insulation thickness and more.
• Thermodynamics
Thermodynamics of steam and condensate systems.
• Control Valves and Equipment
• Pipe Sizing
Sizing of steam and condensate pipe lines - pressure loss, recommended velocity, capacity and more.
• Flash Steam
Flash steam generation - thermodynamic fundamentals, heat loss, energy recovery and more.
Using steam to humidify air.
Air and Steam Mixture
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
ASME - International Boiler and Pressure Vessel Code
The International Boiler and Pressure Vessel Code safety rules governing design, fabrication, and inspection of boilers and pressure vessels, and nuclear power plant components during construction.
Boiler Blowdown
Boiler Blowdown Rate
Calculate boiler blowdown rate.
Boilers - Classification
Classification of boilers according the ASME Boiler and Pressure Vessel Code.
Condensate Generated in Cold Steam Pipes - SI Units
Huge amounts of condensate are generated when cold steam pipes are heated up must be drained from the pipes.
Condensate Generated in Cold Steam Pipes - Sizing of Steam Traps
When cold steam pipes are heated up they generate huge amounts of condensate that must be drained away from the pipe through steam traps - in Imperial Units.
Condensate Pipe Lines - Capacities (kW)
Maximum capacities for condensate pipe lines in kW steam consumption.
Condensate Pipe Lines - Friction Resistance Imperial Units
Friction or major resistance in condensate pipe lines.
Condensate Pipe Lines - Sizing
Flow and pressure loss in condensate return lines - SI Units.
Condensate Pumping
High temperatures and danger of impeller cavitation is the major challenge for condensate pumping in steam systems.
Feed Water - Chemistry Limits
ABMA recommended feed water chemistry limits for steam boilers.
Feeding Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Flash Steam Generation - Imperial Units (psig)
When condensate passes steam traps - flash steam is generated.
Flash Steam Generation - SI-units
When condensate leaves the steam traps - flash steam is generated. Amount of flash steam generated at different pressures - kN/m2.
Flash Steam Generation (bar)
The amount of flash steam generated depends on steam pressure and pressure in the condensate lines.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Fluid Heat Transfer Coefficients in Heat Exchanger Surface Combinations
Heating Systems - Steam and Condensate Loads
Insulated Steam Pipes - Condensate Generated
Heat loss from steam pipes generates condensate which must be drained from the system - imperial units.
Insulated Steam Pipes - Condensate Generated (kg/h per 100m)
Heat loss from steam pipes generates condensate which must be drained from the system.
Low Pressure Steam Safety Valves - Capacities
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr).
NDT - Non Destructive Testing
Non-destructive construction testing.
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Saturated Steam - Properties for Pressure in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Saturated Steam - Properties with Imperial Units
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Soft or Hard Water
Carbonates dissolved in water.
Steam Boiler Rating vs. Feed Water Temperature
Boiler output vs. feed water temperature.
Steam Consumption for some Typical Steam Heated Consumers
Steam consumption rates for typical steam heated consumers in industries like bakeries, breweries, paper factories etc.
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
Steam Heating Systems - Classifications
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Steam Pipes - Heat Losses over a Year
Yearly heat loss in amount of coal or oil consumption for insulated and uninsulated steam pipes at different dimensions and operation times.
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steam Pipes - Installation of Drip Legs
Properly draining steam pipes for condensate.
Steam Pipes - Max. Flow and Pressure Drop
Pressure drop and maximum allowable flow in steam pipes.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steam Radiators and Convectors - Heating Capacities
Steam radiators and steam convectors - heating capacities and temperature coefficients.
Steam Tracing of Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
Steam Trap Selection Guide
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Thermal Expansion of Steam Pipes - inches
Expansion of steam pipes heated from room temperature to operation temperature.
Vapor and Steam
An introduction to vapor and steam.
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Water - Enthalpy (H) and Entropy (S) vs. Temperature
Water - Heat of Vaporization vs. Temperature
Water - Ionization Constant, pKw, of Normal and Heavy water
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water - Saturation Pressure vs. Temperature
Water - Specific Heat vs. Temperature
Water Boiling Points at Higher Pressures
Water-Steam Mollier Diagram
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
