Temperature Expansion
Thermal expansion of pipes and tubes - stainless steel, carbon steel, copper, plastics and more.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Linear Thermal Expansion
Pipes - Temperature Heating Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Steel Pipes - Calculate Thermal Expansion Loops
Calculating and sizing steel pipe thermal expansion loops.
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
