Piping Codes and Standards
American vs. British Piping Standards
US American (ASTM) vs. British (BSi) piping standards - specifications, grades and material descriptions.
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASME - International Boiler and Pressure Vessel Code
The International Boiler and Pressure Vessel Code safety rules governing design, fabrication, and inspection of boilers and pressure vessels, and nuclear power plant components during construction.
ASME - Performance Test Codes
The ASME Performance Test Codes provide standard directions and rules for conducting and reporting tests.
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
ASTM Cross Reference Material Specifications
Cross reference for fittings, flanges, unions and cast and foged valves.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
ASTM International
ASTM International - American Society for Testing and Materials - is a scientific and technical organization that develops and publishes voluntary standards on the characteristics of material, products, systems and services.
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
ASTM International - Volume 01.01 Steel - Piping, Tubing, Fittings
An overview of the ASTM Volume 01.01 standard.
BSi - Pipe, Tube and Fittings Standards and Specifications
British standards and specifications for pipe, tube and fittings.
Carbon and Low-Alloy Steel Classifications
Steel is considered to be carbon steel when no minimum content is specified or required for chromium, cobalt, columbium (niobium), molybdenum, nickel, titanium, tungsten, vanadium or zirconium.
Carbon Steel Pipes - Comparing American & European Standards
Comparing standards of carbon steel pipes from USA, Germany, UK and Sweden.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
DIN - Pipe, Tube and Fittings Standards and Specifications
Deutsches Institut für Normung - DIN - pipe, tube and fittings standards and specifications.
Download ANSI, American National Standards Institute, Standards
ANSI is a private, not-for-profit, membership organization that acts not as a standards developer, but as a standards coordinating and approval body.
Fiberglass Pipes - common Standards
Commonly used standards for fiberglass pipes and their applications.
Flanges - API vs. ASME/ANSI
API and ASME/ANSI flanges - comparing dimensions and pressure ratings.
Fluids - Identity Colors
Identifying colors used for fluid piping systems.
HVAC Abbreviations
Commonly used HVAC abbreviations.
ISO - Pipe, Tube and Fittings Standards and Specifications
International Organization for Standardization - ISO - pipe, tube and fittings standards and specifications.
Japanese industrial flanges, bolts, nuts, and gaskets standards and specifications from JAS - the Japanese Standards Association.
JIS - Japanese Industrial Standards
Japanese Standards Association - JSA.
JIS - Pipe, Tube and Fittings Standards
Japanese industrial pipe, tube and fittings standards and specifications from the Japanese Standards Association - JAS.
NACE International
The corrosion engineering and science community.
NDT - Non Destructive Testing
Non-destructive construction testing.
Pipe Legends - Identification Scheme
Color codes, field and legend.
Piping - Codes & Standards
Piping codes and standards.
PN Pressure Ratings for Flanges: Specifications & Standards
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Steel Pipe Standardization Organizations
World wide steel pipe standardization organizations.
Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
