The amount of steam needed to humidify 100 cfm (cubic feet per minute) of air is indicated below.
| Vapor in 100 cfm air (lb/h) | ||||||||||||||
| Dry Temperature | Humidity (%) | |||||||||||||
| (oF) | (oC) | 100 | 85 | 80 | 75 | 70 | 65 | 60 | 55 | 50 | 45 | 40 | 35 | 30 |
| 90 | 32.2 | 12.8 | 10.9 | 10.3 | 9.6 | 9.0 | 8.3 | 7.7 | 7.1 | 6.4 | 5.8 | 5.1 | 4.5 | 3.9 |
| 88 | 31.1 | 12.1 | 10.3 | 9.7 | 9.1 | 8.5 | 7.9 | 7.3 | 6.6 | 6.1 | 5.4 | 4.8 | 4.2 | 3.6 |
| 86 | 30.0 | 11.4 | 9.7 | 9.1 | 8.5 | 8.0 | 7.4 | 6.9 | 6.3 | 5.7 | 5.1 | 4.6 | 4.0 | 3.4 |
| 85 | 29.4 | 11.0 | 9.4 | 8.8 | 8.3 | 7.7 | 7.2 | 6.6 | 6.1 | 5.5 | 5.0 | 4.4 | 3.9 | 3.3 |
| 84 | 28.9 | 10.7 | 9.1 | 8.5 | 8.0 | 7.5 | 7.0 | 6.4 | 5.9 | 5.3 | 4.8 | 4.3 | 3.7 | 3.2 |
| 83 | 28.3 | 10.4 | 8.8 | 8.3 | 7.8 | 7.3 | 6.7 | 6.2 | 5.7 | 5.2 | 4.7 | 4.2 | 3.6 | 3.1 |
| 82 | 27.8 | 10.1 | 8.6 | 8.0 | 7.6 | 7.1 | 6.5 | 6.1 | 5.5 | 5.0 | 4.5 | 4.0 | 3.5 | 3.0 |
| 81 | 27.2 | 9.8 | 8.3 | 7.8 | 7.3 | 6.8 | 6.4 | 5.9 | 5.4 | 4.9 | 4.4 | 3.9 | 3.4 | 2.9 |
| 80 | 26.7 | 9.5 | 8.0 | 7.6 | 7.1 | 6.7 | 6.2 | 5.7 | 5.2 | 4.7 | 4.3 | 3.8 | 3.3 | 2.8 |
| 79 | 26.1 | 9.2 | 7.8 | 7.3 | 6.9 | 6.4 | 6.0 | 5.5 | 5.1 | 4.6 | 4.1 | 3.7 | 3.2 | 2.7 |
| 78 | 25.6 | 8.9 | 7.6 | 7.1 | 6.7 | 6.2 | 5.8 | 5.3 | 4.9 | 4.4 | 4.0 | 3.6 | 3.1 | 2.7 |
| 77 | 25.0 | 8.6 | 7.3 | 6.9 | 6.5 | 6.1 | 5.6 | 5.2 | 4.7 | 4.3 | 3.9 | 3.5 | 3.0 | 2.6 |
| 76 | 24.4 | 8.4 | 7.1 | 6.7 | 6.3 | 5.9 | 5.5 | 5.0 | 4.6 | 4.2 | 3.8 | 3.4 | 2.9 | 2.5 |
| 75 | 23.9 | 8.1 | 6.9 | 6.5 | 6.1 | 5.7 | 5.3 | 4.9 | 4.5 | 4.1 | 3.6 | 3.2 | 2.8 | 2.4 |
| 74 | 23.3 | 7.9 | 6.7 | 6.3 | 5.9 | 5.5 | 5.1 | 4.7 | 4.3 | 3.9 | 3.5 | 3.1 | 2.7 | 2.4 |
| 73 | 22.8 | 7.6 | 6.5 | 6.1 | 5.7 | 5.3 | 4.9 | 4.6 | 4.1 | 3.8 | 3.4 | 3.1 | 2.7 | 2.3 |
| 72 | 22.2 | 7.4 | 6.3 | 5.9 | 5.5 | 5.2 | 4.8 | 4.4 | 4.1 | 3.7 | 3.3 | 2.9 | 2.6 | 2.2 |
| 71 | 21.7 | 7.1 | 6.1 | 5.7 | 5.3 | 5.0 | 4.6 | 4.3 | 3.9 | 3.6 | 3.2 | 2.9 | 2.5 | 2.1 |
| 70 | 21.1 | 6.9 | 5.9 | 5.5 | 5.4 | 4.8 | 4.5 | 4.1 | 3.8 | 3.5 | 3.1 | 2.8 | 2.4 | 2.1 |
| 69 | 20.6 | 6.7 | 5.7 | 5.4 | 5.0 | 4.7 | 4.4 | 4.0 | 3.7 | 3.4 | 3.0 | 2.7 | 2.4 | 2.0 |
| 68 | 20.0 | 6.5 | 5.5 | 5.2 | 4.9 | 4.5 | 4.2 | 3.9 | 3.5 | 3.2 | 2.9 | 2.6 | 2.3 | 1.9 |
| 67 | 19.4 | 6.2 | 5.3 | 5.0 | 4.7 | 4.4 | 4.1 | 3.7 | 3.4 | 3.1 | 2.8 | 2.5 | 2.2 | 1.9 |
| 66 | 18.9 | 6.1 | 5.2 | 4.9 | 4.5 | 4.2 | 3.9 | 3.6 | 3.3 | 3.0 | 2.7 | 2.4 | 2.1 | 1.8 |
| 65 | 18.3 | 5.9 | 5.0 | 4.7 | 4.4 | 4.1 | 3.8 | 3.5 | 3.2 | 2.9 | 2.6 | 2.3 | 2.1 | 1.8 |
| 60 | 15.6 | 5.0 | 4.2 | 4.0 | 3.7 | 3.5 | 3.2 | 3.0 | 2.7 | 2.5 | 2.2 | 2.0 | 1.7 | 1.5 |
| 55 | 12.8 | 4.2 | 3.6 | 3.4 | 3.1 | 2.9 | 2.7 | 2.5 | 2.3 | 2.1 | 1.9 | 1.7 | 1.5 | 1.3 |
| 50 | 10.0 | 3.5 | 3.0 | 2.8 | 2.6 | 2.5 | 2.3 | 2.11 | 1.9 | 1.8 | 1.6 | 1.4 | 1.2 | 1.1 |
| 45 | 7.2 | 2.9 | 2.5 | 2.4 | 2.2 | 2.1 | 1.9 | 1.8 | 1.6 | 1.5 | 1.3 | 1.2 | 1.0 | 0.89 |
| 40 | 4.4 | 2.5 | 2.1 | 2.0 | 1.8 | 1.7 | 1.6 | 1.5 | 1.3 | 1.2 | 1.1 | 1.0 | 0.86 | 0.74 |
| 30 | -1.1 | 1.7 | 1.4 | 1.3 | 1.2 | 1.2 | 1.1 | 1.0 | 0.92 | 0.83 | 0.75 | 0.67 | 0.58 | 0.50 |
| 20 | -6.7 | 1.1 | 0.91 | 0.85 | 0.80 | 0.75 | 0.70 | 0.64 | 0.59 | 0.53 | 0.48 | 0.43 | 0.37 | 0.32 |
| 10 | -12.2 | 0.67 | 0.56 | 0.53 | 0.50 | 0.47 | 0.43 | 0.40 | 0.37 | 0.33 | 0.30 | 0.26 | 0.23 | 0.20 |
| 0 | -17.8 | 0.41 | 0.35 | 0.32 | 0.31 | 0.29 | 0.26 | 0.25 | 0.22 | 0.20 | 0.19 | 0.16 | 0.13 | 0.12 |
| -10 | -23.3 | 0.25 | 0.21 | 0.2 | 0.19 | 0.17 | 0.16 | 0.15 | 0.14 | 0.12 | 0.11 | 0.10 | 0.08 | 0.08 |
| -20 | -28.9 | 0.14 | 0.12 | 0.11 | 0.11 | 0.10 | 0.10 | 0.08 | 0.08 | 0.72 | 0.06 | 0.05 | 0.05 | 0.04 |
- 100 cfm = 0.047 m3/s = 170 m3/h
- 1 lb/h = 0.4536 kg/h
Example - Humidifying Air with Steam
How much steam is needed to transform air at 30 oF with 100% humidity to air at 70 oF with 40% humidity?
- air at 30 oF and 100% humidity - steam content 1.67 lb/h (100 cfm/h air flow)
- air at 70 oF and 40% humidity - steam content 2.76 lb/h (100 cfm/h air flow)
The difference (2.76 - 1.67) = 1.09 lb/h is the amount of steam needed for 100 cfm/h air flow.
Note!
This table neglects the sensible heat required to heat cold air to final state. In the example above the heat required to heat 100 cfm dry air from 30 oF to 70 oF must be added. The heat can be added as dry heat with heating panels or similar, or in general more convenient by adding more steam.
• Air Psychrometrics
• Steam and Condensate
Air - Absolute Humidity
Absolute humidity is the actual mass of water vapor present in the air water vapor mixture.
Basic air changing state processes - heating, cooling, mixing, humidifying and dehumidifying by adding steam or water - psychometric diagrams and the Mollier charts.
Using steam to humidify air.
Air - Humidity Ratio
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart to analyze air properties, including temperature, humidity, enthalpy, and dew point at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Humidifiers
Sprayed coils, spinning discs and steam humidifiers.
Steam Heating Air
Vapor and Steam
An introduction to vapor and steam.
