Gases - Gross and Net Heat Values
Gross heating and net heating values for some common gases can be found in the table below:
| Gas | (kcal/kg) | (kcal/nm3)1) | ||
| Gross Heating Values | Net Heating Values | Gross Heating Values | Net Heating Values | |
| Hydrogen | 33889 | 28555 | 3050 | 2570 |
| Methane | 13284 | 11946 | 9530 | 8570 |
| Ethane | 12400 | 11350 | 16700 | 15300 |
| Ethylene | 12020 | 11270 | 15100 | 14200 |
| Natural Gas - approximately | 12000 | 11000 | 9000 | 8000 |
| Propane | 12030 | 11080 | 24200 | 22250 |
| Propylene | 11700 | 10940 | 22400 | 20900 |
| n-Butane | 11830 | 10930 | 31900 | 29400 |
| Iso-Butane | 11810 | 10900 | 31700 | 29200 |
| Butylene-1 | 11580 | 10830 | 29900 | 27900 |
| Iso-Pentane (liquid) | 11600 | 10730 | ||
| LPG (average) | 11920 | 10997 | 28000 | 25775 |
| Acetylene | 11932 | 11514 | 13980 | 13490 |
| Carbon Monoxide | 2411 | 2411 | 3014 | 3014 |
1) nm3 = normal cubic metre
- 1 kJ/kg = 1 J/g = 0.4299 Btu/ lbm = 0.23884 kcal/kg
- Unit Converter
• Combustion
Acetylene - Thermophysical Properties
Chemical, Physical and Thermal Properties of Acetylene.
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Combustion Heat
Food - Calorific Combustion Values
Combustion heat values of some foods.
Fuel Gases - Combustion Values
Combustion values for fuel gases like natural gas, propane and butane - Btu per cubic feet.
Fuel Gases - Wobbe Index
Wobbe index for fuel gases like propane, butane, methane and more.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
High and Low Heat Values
The gross (high) and net (low) heating values.
LNG - Liquefied Natural Gas
LNG or Liquefied Natural Gas.
LPG - Liquefied Petroleum Gas
LPG or Liquefied Petroleum Gas.
LPG Pipes - Pressure Loss vs. Gas Flow
Resistance and pressure loss in liquid LPG pipes.
