Concentration Units Converter
Online Units Concentration Calculator
The calculator below can be used to convert between common concentration units. The mole weight of the solvent and solute and the density of the solution must be filled in:
Density of water solutions of: organic acids, organic substances as sugars and alcohols, inorganic chlorides, inorganic sodium salts, inorganic potassium salts and some other inorganic substances .
See also Solutions, molarity and dilution, Mixtures, Solutions and Suspensions and Solubility product constants.
The fomulas used by the calculater is given in the table below:
| Desired unit - as function of | Wt% | Molality | Molarity | Mole fraction | g solute/l solution |
| Wt% of solute | 100*E*B 1000 + E*B |
F*B 10*C |
100*G*B G*B + (1 - G)*A |
H 10*C |
| Molality, mol/kg solvent | 1000*D B*(100 - D) |
1000*F 1000*C - F*B |
1000*G A - G*A |
1000*H B*(1000*C - H) |
| Molarity, mol/liter solution | 10*C*D B |
1000*C*E 1000 + B*E |
1000*C*G G*B + (1 - G)*A |
H B |
| Mole fraction, molsolute /moltotal | D/B D/B + (100 - D)/A |
A*E A*E + 1000 |
A*F F*(A - B) + 1000*C |
A*H H*(A - B) + 1000*C*B |
| Gram of solute/liter solution | 10*D*C | 1000*C*E*B 1000 + E*B |
F*B | 1000*C*G*B G*B + (1-G)*A |
A = mole weight of solvent, g/mol
B = mole weight of solute, g/mol
C = density of solution*, g/ml
D = wt% of solute
E = molality, mol/kg solvent
F = molarity, mol/liter solution
G = mole fraction, molsolute /moltotal
H = gram of solute/liter solution
* Density is not needed for conversons between wt%, mole fraction and molality or between molarity and grams of solute per liter solution.
Density of low viscous liquids can be measured by exact weighing of a well-defined volume of the liquid. Then, the density is calculated by using the formula
density = mass (g) / volume (ml)
Density of water solutions of: organic acids, sugar and alchohols, inorganic chlorides, inorganic potassium salts, inorganic sodium salts, other common inorganic substanses
Shrinkage and estimation of density of a liquid-liquid solution
How to measure density of petroleum products
Descriptive Terms for Solubility
| Descriptive Term | Parts of solvent required for 1 part of solute |
| Very soluble | < 1 |
| Freely soluble | 1 < 10 |
| Soluble | 10 < 30 |
| Sparingly soluble | 30 < 100 |
| Slightly soluble | 100 < 1000 |
| Very slightly soluble | 1000 < 10000 |
| Pracically insoluble (Insoluble) | > 10000 |
• Basics
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Density Converter
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Mixtures vs. solutions vs. suspensions.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Unit Factor Method
