Clo - Clothing and Thermal Insulation
The insulation effect of clothes can be measured in the unit "Icl, Clo" - where
1 Clo = 0.155 m2K/W
- Clo = 0 - corresponds to a naked person
- Clo = 1 - corresponds to the insulating value of clothing needed to maintain a person in comfort sitting at rest in a room at 21 ℃ (70 ℉) with air movement of 0.1 m/s and humidity less than 50% - typically a person wearing a business suit
| Clothing | Insulation | ||
| Icl, Clo | m2K/W | ||
| Nude | 0 | 0 | |
| Underwear - pants | Pantyhose | 0.02 | 0.003 |
| Panties | 0.03 | 0.005 | |
| Briefs | 0.04 | 0.006 | |
| Pants 1/2 long legs made of wool | 0.06 | 0.009 | |
| Pants long legs | 0.1 | 0.016 | |
| Underwear - shirts | Bra | 0.01 | 0.002 |
| Shirt sleeveless | 0.06 | 0.009 | |
| T-shirt | 0.09 | 0.014 | |
| Shirt with long sleeves | 0.12 | 0.019 | |
| Half-slip in nylon | 0.14 | 0.022 | |
| Shirts | Tube top | 0.06 | 0.009 |
| Short sleeve | 0.09 | 0.029 | |
| Light blouse with long sleeves | 0.15 | 0.023 | |
| Light shirt with long sleeves | 0.20 | 0.031 | |
| Normal with long sleeves | 0.25 | 0.039 | |
| Flannel shirt with long sleeves | 0.30 | 0.047 | |
| Long sleeves with turtleneck blouse | 0.34 | 0.053 | |
| Trousers | Shorts | 0.06 | 0.009 |
| Walking shorts | 0.11 | 0.017 | |
| Light trousers | 0.20 | 0.031 | |
| Normal trousers | 0.25 | 0.039 | |
| Flannel trousers | 0.28 | 0.043 | |
| Overalls | 0.28 | 0.043 | |
| Coveralls | Daily wear, belted | 0.49 | 0.076 |
| Work | 0.50 | 0.078 | |
| Highly-insulating coveralls | Multi-component with filling | 1.03 | 0.160 |
| Fiber-pelt | 1.13 | 0.175 | |
| Sweaters | Sleeveless vest | 0.12 | 0.019 |
| Thin sweater | 0.20 | 0.031 | |
| Long thin sleeves with turtleneck | 0.26 | 0.040 | |
| Thick sweater | 0.35 | 0.054 | |
| Long thick sleeves with turtleneck | 0.37 | 0.057 | |
| Jacket | Vest | 0.13 | 0.020 |
| Light summer jacket | 0.25 | 0.039 | |
| Smock | 0.30 | 0.047 | |
| Jacket | 0.35 | 0.054 | |
| Coats and over-jackets and over-trousers | Overalls multi-component | 0.52 | 0.081 |
| Down jacket | 0.55 | 0.085 | |
| Coat | 0.60 | 0.093 | |
| Parka | 0.70 | 0.109 | |
| Sundries | Socks | 0.02 | 0.003 |
| Thin soled shoes | 0.02 | 0.003 | |
| Quilted fleece slippers | 0.03 | 0.005 | |
| Thick soled shoes | 0.04 | 0.006 | |
| Thick ankle socks | 0.05 | 0.008 | |
| Boots | 0.05 | 0.008 | |
| Thick long socks | 0.10 | 0.016 | |
| Skirts, dresses | Light skirt 15 cm. above knee | 0.01 | 0.016 |
| Light skirt 15 cm. below knee | 0.18 | 0.028 | |
| Heavy skirt knee-length | 0.25 | 0.039 | |
| Light dress sleeveless | 0.25 | 0.039 | |
| Winter dress long sleeves | 0.40 | 0.062 | |
| Sleepwear | Under shorts | 0.10 | 0.016 |
| Short gown thin strap | 0.15 | 0.023 | |
| Long gown long sleeve | 0.30 | 0.047 | |
| Hospital gown | 0.31 | 0.048 | |
| long pajamas with long sleeve | 0.50 | 0.078 | |
| Body sleep with feet | 0.72 | 0.112 | |
| Robes | Long sleeve, wrap, short | 0.41 | 0.064 |
| Long sleeve, wrap, long | 0.53 | 0.082 | |
An overall insulation - or Clo - value can be calculated by simply taking the Clo value for each individual garment worn by a person and adding them together. The mean surface area of the human body is approximately 1.8 m2.
Example - Clothing Ensemble
| Cloth | Icl |
| Briefs | 0.04 |
| Shoes | 0.02 |
| Socks | 0.03 |
| Short sleeve shirt | 0.19 |
| Straight trousers | 0.15 |
| Total | 0.43 |
• Physiology
Age and Physical Growth - Weight and Height
Age and typical physical growth of boys and girls - age 2 to 18 years.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Clothing Sizes - US vs. UK and Europe
Comparing European, UK, US sizing in clothing, shoes, shirts and sweaters.
Clothing, Activity and Human Metabolism
Human metabolism at low and high activity with different levels of clothing.
Discomfort Index
Comfort vs. dry bulb, wet bulb and dew point temperature.
Globe Temperature
The resultant or globe temperature.
Heat Discomfort Zones
Maximum work load vs. temperature and relative humidity.
Heat Index vs. Humidity
The influence of humidity on the apparent temperature and the heat index.
Indoor Comfort Temperatures vs. Outdoor Temperatures
Recommended indoor comfort temperatures vs. outdoor temperatures.
Indoor Conditions - Summer or Winter
Recommended indoor design conditions summer or winter.
Indoor Design Temperatures
Recommended indoor temperatures in summer or winter.
Indoor Temperature and Humidity Loads
Calculate sensible and latent heat from persons, lights, electric equipment, machines, evaporation from water surfaces, polluting fluids and miscellaneous loads.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Met - Human Metabolic Rates
Metabiolic Rate - Met - is used as a measuring unit for human body heat or power production.
Physiology - Activity and Metabolic Rates
Heat production from the human body vs. activity.
Predicted Mean Vote Index (PMV)
PMV index predicts mean comfort response of a larger group of people.
Recommended Relative Humidity
Recommended relative humidity level.
