Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
  • Driveways : 6 - 8 inches ( 0.15 - 0.2 m)
  • Side walks, barn and granny floors : 5 - 6 inches (0.125 - 0.15 m)
  • Porches, Home garage floors : 4 - 5 inches (0.1 - 0.125 m)
  • Farm building floors, Home basement floors : 4 inches (0.1 m)
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 10
