Concrete Slabs - Load Capacities
Load capacities of simply supported concrete slabs:
| Thickness (mm) | Self Weight (kg/m2) | Imposed Load (kg/m2) | Total Load | Span (m) | |
| kg/m2 | kN/m2 | ||||
| 100 | 240 | 500 | 740 | 7.26 | 2.4 |
| 125 | 300 | 500 | 800 | 7.85 | 3.0 |
| 150 | 360 | 500 | 860 | 8.44 | 3.6 |
Imposed loads varies from approximately 1.5 kN/m2 (153 kg/m2) in domestic buildings to approximately 10 kN/m2 (1053 kg/m2) in heavy industrial areas. 500 kg/m2 is typical for office, storage space and similar.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Floor Joist Capacities
Floors - Live Loads
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Mortar Types
ASTM mortar types.
Typical Floor Loads
Uniformly and concentrated floor loads
