Steam & Condensate Equations
Some common steam and condensate equations:
Steam Heating
ms = h / 960 (1)
ms = steam mass flow rate (lbs/hr)
h = heat flow rate (Btu/hr)
Steam Heating Liquid Flow
ms = ql 500 SGl Cpl dtl/ Ls (2)
ql= volume flow liquid (gallons per minute, gpm)
Cpl= specific heat capacity of liquid (Btu/lb oF)
SGl= specific gravity of fluid
dtl= temperature difference liquid (oF)
Ls= latent heat steam (Btu/lb)
Steam Heating Air or Gas Flow
ms = qg 60 ρg Cpg dtg / Ls (3)
ms = steam mass flow rate (lbs./hr)
qg = volume flow gas (cubic feet per minute, cfm)
ρg = density of the gas (lb/ft3)
Cpg = specific gravity of the gas
dtg = temperature difference gas (oF)
Ls = latent heat steam (Btu/lb)
• Thermodynamics
Condensate Generated in Cold Steam Pipes - SI Units
Huge amounts of condensate are generated when cold steam pipes are heated up must be drained from the pipes.
Condensate Generated in Cold Steam Pipes - Sizing of Steam Traps
When cold steam pipes are heated up they generate huge amounts of condensate that must be drained away from the pipe through steam traps - in Imperial Units.
Flash Steam Generation - Fundamental Physics
Tutorial to the basic physics behind flash steam generation
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam Consumption for some Typical Steam Heated Consumers
Steam consumption rates for typical steam heated consumers in industries like bakeries, breweries, paper factories etc.
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
Steam Heating Systems - Classifications
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
