Stainless steel pipes are used in constructions, food industry, pharmaceutical industry, petrochemical industry, automotive industry, municipal and decorative purposes.
Range of Stainless Steel pipes according to ANSI/ASME 36.19M - Stainless Steel Pipe.
For full table with Schedule 80S - rotate the screen!
| Nominal Pipe Size (inches) | Outside Diameter | Schedule | ||||||||
| 5S | 10S | 40S | 80S | |||||||
| (mm) | (inches) | Wall Thickness and Weight | ||||||||
| mm (in) | kg/m | mm (in) | kg/m | mm (in) | kg/m | mm (in) | kg/m | |||
| 1/8 | 10.3 | 0.405 | - | - | 1.25 (0.049) |
0.28 | 1.73 (0.068) |
0.37 | 2.42 (0.095) |
0.47 |
| 1/4 | 13.7 | 0.540 | - | - | 1.66 (0.065) |
0.49 | 2.24 (0.088) |
0.63 | 3.03 (0.119) |
0.80 |
| 3/8 | 17.2 | 0.675 | - | - | 1.66 (0.065) |
0.63 | 2.32 (0.091) |
0.85 | 3.20 (0.126) |
1.10 |
| 1/2 | 21.3 | 0.840 | 1.65 (0.065) |
0.81 | 2.11 (0.083) |
1.00 | 2.77 (0.109) |
1.27 | 3.74 (0.147) |
1.62 |
| 3/4 | 26.7 | 1.050 | 1.65 (0.065) |
1.02 | 2.11 (0.083) |
1.28 | 2.87 (0.113) |
1.68 | 3.92 (0.154) |
2.20 |
| 1 | 33.4 | 1.315 | 1.65 (0.065) |
1.30 | 2.77 (0.109) |
2.09 | 3.38 (0.133) |
2.50 | 4.55 (0.179) |
3.24 |
| 1 1/4 | 42.2 | 1.660 | 1.65 (0.065) |
1.66 | 2.77 (0.109) |
2.69 | 3.56 (0.140) |
3.39 | 4.86 (0.191) |
4.47 |
| 1 1/2 | 48.3 | 1.900 | 1.65 (0.065) |
1.91 | 2.77 (0.109) |
3.11 | 3.69 (0.145) |
4.06 | 5.08 (0.200) |
5.41 |
| 2 | 60.3 | 2.375 | 1.65 (0.065) |
2.40 | 2.77 (0.109) |
3.93 | 3.92 (0.154) |
5.45 | 5.54 (0.218) |
7.49 |
| 2 1/2 | 73.0 | 2.875 | 2.11 (0.083) |
3.69 | 3.05 (0.120) |
5.26 | 5.16 (0.203) |
8.64 | 7.01 (0.276) |
11.4 |
| 3 | 88.9 | 3.500 | 2.11 (0.083) |
4.52 | 3.05 (0.120) |
6.46 | 5.49 (0.216) |
11.3 | 7.62 (0.300) |
15.3 |
| 3 1/2 | 101.6 | 4.000 | 2.11 (0.083) |
5.18 | 3.05 (0.120) |
7.41 | 5.74 (0.226) |
13.6 | 8.08 (0.318) |
18.6 |
| 4 | 114.3 | 4.500 | 2.11 (0.083) |
5.84 | 3.05 (0.120) |
8.37 | 6.02 (0.237) |
16.1 | 8.56 (0.337) |
22.3 |
| 5 | 141.3 | 5.563 | 2.77 (0.109) |
9.46 | 3.41 (0.134) |
11.6 | 6.56 (0.258) |
21.8 | 9.53 (0.375) |
31.0 |
| 6 | 168.3 | 6.625 | 2.77 (0.109) |
11.3 | 3.41 (0.134) |
13.9 | 7.12 (0.280) |
28.3 | 10.98 (0.432) |
42.6 |
| 8 | 219.1 | 8.625 | 2.77 (0.109) |
14.8 | 3.76 (0.148) |
20.0 | 8.18 (0.322) |
42.5 | 12.70 (0.500) |
64.6 |
| 10 | 273.1 | 10.750 | 3.41 (0.134) |
22.7 | 4.20 (0.165) |
27.8 | 9.28 (0.365) |
60.4 | 12.70 (0.500) |
81.5 |
| 12 | 323.9 | 12.750 | 3.97 (0.156) |
31.3 | 4.58 (0.180) |
36.1 | 9.53 (0.375) |
73.9 | 12.70 (0.500) |
97.4 |
- ANSI/ASME 36.19M Stainless Steel Pipe - covers the standardization of dimensions of welded and seamless wrought stainless steel pipe
- Stainless Steel Fittings
• Piping Systems
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM A270 Sanitary Stainless Steel Tubing - Dimensions
Dimensions of ASTM A270 sanitary steel tubes.
Composition of Steels
Typical composition of AISI steels.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Pressure loss nomogram for hot water steel pipes.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Pipe Weight Calculator
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Pressfit Piping - Dimensions
Dimension of pressfit pipes.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Steel Flats - Weights
Steel Pipes - Weight
Steel Plate Weight Guide: Calculator & Data Table
Vacuum Pumps - Exhaust Pipe Capacities
Capacities of vacuum pump exhaust pipes.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
