Stainless Steels - Corrosion Resistance
Corrosion resistance of AISI Stainless Steels in typical environments:
For full table with Oxidizing and Reducing Chemicals - rotate the screen!
| AISI Type | Fresh Water and Mild Atmospheric Environments | Industrial Environments | Marine Environments | Mild Chemicals | Oxidizing Chemicals | Reducing Chemicals |
| 201 | • | • | • | • | • | |
| 202 | • | • | • | • | • | |
| 205 | • | • | • | • | • | |
| 301 | • | • | • | • | • | |
| 302 | • | • | • | • | • | |
| 302B | • | • | • | • | • | |
| 303 | • | • | • | • | ||
| 303 Se | • | • | • | • | ||
| 304 | • | • | • | • | • | |
| 304L | • | • | • | • | • | |
| 304N | • | • | • | • | • | |
| 305 | • | • | • | • | • | |
| 308 | • | • | • | • | • | |
| 309 | • | • | • | • | • | |
| 309S | • | • | • | • | • | |
| 310 | • | • | • | • | • | |
| 310S | • | • | • | • | • | |
| 314 | • | • | • | • | • | |
| 316 | • | • | • | • | • | • |
| 316F | • | • | • | • | • | • |
| 316L | • | • | • | • | • | • |
| 316N | • | • | • | • | • | • |
| 317 | • | • | • | • | • | • |
| 317L | • | • | • | • | • | |
| 321 | • | • | • | • | • | |
| 329 | • | • | • | • | • | • |
| 330 | • | • | • | • | • | • |
| 347 | • | • | • | • | • | |
| 348 | • | • | • | • | • | |
| 384 | • | • | • | • | • | |
| 403 | • | • | ||||
| 405 | • | • | ||||
| 409 | • | • | ||||
| 410 | • | • | ||||
| 414 | • | • | ||||
| 416 | • | |||||
| 416 Se | • | |||||
| 420 | • | |||||
| 420F | • | |||||
| 422 | • | |||||
| 429 | • | • | • | • | ||
| 430 | • | • | • | • | ||
| 430F | • | • | • | |||
| 430F Se | • | • | • | |||
| 431 | • | • | • | • | ||
| 434 | • | • | • | • | • | |
| 436 | • | • | • | • | • | |
| 440A | • | • | ||||
| 440B | • | |||||
| 440C | • | |||||
| 442 | • | • | • | • | ||
| 446 | • | • | • | • | • |
• considered as resistant to the environment category
• Corrosion
AISI 310 Stainless Steel - Properties
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
