Surface Roughness vs. Mechanical Processing
Surface roughness from mechanical processing like
  • honing
  • flame cutting
  • snagging
  • sawing
  • planning, shaping
  • drilling
  • broaching
  • reaming
  • electron beam
  • laser
  • electro-chemical
  • boring, turning
  • barrel finishing
  • electrolytic grinding
  • roller burnishing
  • grinding
  • electro-polishing
  • polishing
  • lapping
  • superfinishing
  • sand casting
  • hot rolling
  • forging
  • investment casting
  • extruding
  • cold rolling, drawing
  • die casting
are indicated in the diagram below:
Miscellaneous
Building Tolerances
Typical tolerances for floors, walls, columns and more.
Chezys Conduit Flow Equation
Calculating volume flow and velcity in open conduits.
Grit Size vs. Surface Roughness
Comparing sandpaper grit size and surface roughness.
Machine Processing - Tolerance Grades
Machine processing and tolerance grades.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Manning’s Roughness Coefficients for Open Channel Flow
Manning's roughness coefficients for some common materials.
Moody Diagram
Calculate fluid flow friction coefficients from a Moody diagram.
Sandpapers - Grit Sizes
Grit sizes ranging 12 - 600.
Scales of Objects
The relative scale of objects.
Sieve Sizes vs. Mesh Designations
US commercial sieve sizes vs. mesh designations.
Surface Roughness Coefficients
Surface coefficients that can be used to calculate friction and major pressure loss for fluid flow with surfaces like concrete, galvanized steel, corroded steel and more.
Surface Roughness vs. Abrasive Grain Size
U.S. mesh size vs. surface roughness.
