Compressed Water - Properties vs. Temperature
Specific volume (v), enthalpy (h), and entropy (s) of compressed water:
| Saturation properties | Temperature - t - (oC) | |||||||
| 0.01 | 100 | 200 | 250 | 300 | 350 | 374.15 | ||
| pressure (bar) |
ps | 0.006112 | 1.01325 | 15.55 | 39.78 | 85.92 | 165.4 | 221.2 |
| specific volume (m3/kg) |
vf 102 | 0.1000 | 0.1044 | 0.1157 | 0.1251 | 0.1404 | 0.1741 | 0.317 |
| specific enthalpy (kJ/kg) |
hf | 0 | 419 | 852 | 1086 | 1345 | 1671 | 2084 |
| specific entropy (kJ/kg K) |
sf | 0 | 1.307 | 2.331 | 2.793 | 3.255 | 3.779 | 4.430 |
| Pressure - p - (bar) | Properties | |||||||
| 1001) | (v-vf) 102 | -0.0005 | -0.0006 | -0.0009 | -0.0011 | -0.0007 | ||
| (h-hf) | +10 | +7 | +4 | 0 | -2 | |||
| (s-sf) | 0.000 | -0.008 | -0.013 | -0.014 | -0.007 | |||
| 221.22) | (v-vf) 102 | -0.0011 | -0.0012 | -0.0020 | -0.0029 | -0.0051 | -0.0107 | 0 |
| (h-hf) | +22 | +17 | +9 | +1 | -12 | -34 | 0 | |
| (s-sf) | +0.001 | -0.017 | -0.031 | -0.040 | -0.053 | -0.071 | 0 | |
| 500 | (v-vf) 102 | -0.0023 | -0.0024 | -0.0042 | -0.0064 | -0.0117 | -0.0298 | -0.161 |
| (h-hf) | +49 | +38 | +23 | +8 | -21 | -94 | -369 | |
| (s-sf) | 0.000 | -0.037 | -0.068 | -0.091 | -0.134 | -0.235 | -0.670 | |
| 1000 | (v-vf) 102 | -0.0044 | -0.0044 | -0.0075 | -0.0111 | -0.0191 | -0.0427 | -0.180 |
| (h-hf) | +96 | +76 | +51 | +28 | -17 | -119 | -415 | |
| (s-sf) | -0.007 | -0.070 | -0.124 | -0.164 | -0.235 | -0.385 | -0.853 | |
1) Saturation temperature (ts) 311.0 oC
2) Saturation temperature (ts) 374.15 oC
Supercooled Water - Vapor Pressure vs. Temperature
Undercooled water and vapor pressure.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
