Cavitation
Cavitation is a common problem in pumps and control valves - causing serious wear, tear and damage. Under the wrong conditions cavitation reduces components life time dramatically.
What is Cavitation?
Cavitation may occur when local static pressure in a fluid reach a level below the vapor pressure of the liquid at the actual temperature. According the Bernoulli Equation this may happen when a fluid accelerates in a control valve or around a pump impeller.
The vaporization itself does not cause the damage - the damage happens when the vapor almost immediately after evaporation collapses when velocity decreases and pressure increases.
Avoiding Cavitation
Cavitation can in general be avoided by
- increasing the distance (pressure difference) between the actual local static pressure in the fluid - and the vapor pressure of the fluid at the actual temperature
This can be done by:
- re-engineering components initiating high speed velocities and low static pressures
- increasing the total or local static pressure in the system
- reducing the temperature of the fluid
Re-engineering of Components Initiating High Speed Velocity and Low Static Pressure
Cavitation and damage can be avoided by using special components designed for the actual rough conditions.
- conditions with huge pressure drops can - with limitations - be handled by Multi Stage Control Valves
- challenging pumping conditions with fluid temperatures close to the vaporization temperature can be handled with special pumps - working after other principles than centrifugal pumps
Increasing the Total or Local Pressure in the System
By increasing the total or local pressure in the system the distance between the static pressure and the vaporization pressure is increased and vaporization and cavitation can be avoided.
The ratio between static pressure and the vaporization pressure - an indication of the possibility of vaporization, is often expressed by the Cavitation Number.
Unfortunately it is not always possible to increase total static pressure due to systems classifications or other limitations. Local static pressure in components may be increased by lowering (elevation) the component in the system. Control valves and pumps should in general be positioned in the lowest part of a system to maximize the static head.
This is a common solution for boiler feeding pumps receiving hot condensate (water close to 100 oC) from condensate receivers in steam plants.
Reducing the Fluid Temperature
Vaporization pressure depends of fluid temperature. The vapor pressure for water - our most common fluid - is indicated below:
| Temperature (oC) | Vapor Pressure (kPa, kN/m2) |
| 0 | 0.6 |
| 5 | 0.9 |
| 10 | 1.2 |
| 15 | 1.7 |
| 20 | 2.3 |
| 25 | 3.2 |
| 30 | 4.3 |
| 35 | 5.6 |
| 40 | 7.7 |
| 45 | 9.6 |
| 50 | 12.5 |
| 55 | 15.7 |
| 60 | 20 |
| 65 | 25 |
| 70 | 32.1 |
| 75 | 38.6 |
| 80 | 47.5 |
| 85 | 57.8 |
| 90 | 70 |
| 95 | 84.5 |
| 100 | 101.33 |
Note! - be aware that evaporation pressure - and possible cavitation - increases dramatically with water temperature.
Cavitation can be avoided by locating components to the coldest part of systems. Example - it is common to locate pumps and modulating valves in heating systems in the "cold" return lines before heaters and heat-exchangers.
• Pumps
Boiler Feed Water - Chemistry and Impurity Limits
ABMA recommended feed water chemistry limits for steam boilers.
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Cavitation Number
An introduction and definition of the Cavitation Number.
Condensate Pumping
High temperatures and danger of impeller cavitation is the major challenge for condensate pumping in steam systems.
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Valves - Typical Operating Temperatures
Operating temperatures for typical categories of valves - ball valves, butterfly valves and more.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
