ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
ABS (Acrylonitrile Butadiene Styrene) is used for
- interior and exterior sanitary
- industrial drainage and vent systems
- pressurized liquid lines for salt water, irrigation and crude oil
- pumped waste
ABS is approved for potable water systems. ABS is slightly more rigid than PVC. ABS is one of the least resistant plastic to solvents.
Upper service temperature is 175°F (80°C).
Dimensions of ABS pipes according ASTM D2661 Standard Specification for Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings.
| Nominal Pipe Size (in) | Average Outside Diameter (in) | Wall Thickness (in) | Inside Diameter (in) | Weight (lb/ft) |
| 1 1/4 | 1.660 | 0.140 | 1.385 | 0.32 |
| 1 1/2 | 1.900 | 0.145 | 1.615 | 0.38 |
| 2 | 2.375 | 0.154 | 2.072 | 0.51 |
| 3 | 3.500 | 0.216 | 3.075 | 1.04 |
| 4 | 4.500 | 0.237 | 4.033 | 1.51 |
| 6 | 6.625 | 0.280 | 6.070 | 2.64 |
ABS Pipes - Pressure Ratings
Pressure ratings of ABS 1208, ABS 1210, ABS 1316 and ABS 2112.
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Dimensions of PVC pipes according EN 1401.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
ISO - Pipe, Tube and Fittings Standards and Specifications
International Organization for Standardization - ISO - pipe, tube and fittings standards and specifications.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
