Roof Framing
Run
Run can be calculated as:
R = S / 2                        (1)
R = run (ft, m)
S = span (ft, m)
Example - Run
The run of a roof with 60 feet span is
R = (60 feet) / 2
  = 30 feet
Gable Height
Gable height can be calculated as
GH = R VR                       (2)
GH = gable height (ft, m)
R = run (ft, m)
VR = vertical rise (in/ft, cm/m)
Example - Gable Height
The Gable Height of a roof with 30 feet run and vertical rice 6 inches per foot, can be calculated as
GH = (30 feet) (6 inches/foot)
     = 180 inches
     = 15 feet
Gable Area
Gable Area can be calculated as
GA = GH R                        (3)
GA = gable area (sq.ft, m2)
R = run (ft, m)
Roof Slope
Roof slope is the ratio between the vertical rise and the horizontal run:
RS = y / x                      (4)
RS = roof slope
y = vertical rise (in, m)
x = horizontal run (in, m)
In the United States, slope is typically given in inches per 1 foot or as a ratio of inches per 12 inches and is often referred to with units of "pitch". Ex.
4 in 12
or
4 pitches, 4:12 pitch
In metric countries it is common to use degrees or 10 or 100 as denominator. Ex.
21.8%
or
4:10
Slope/Inclination Degree, Gradient and Grade Calculator
Miscellaneous
Building Tolerances
Typical tolerances for floors, walls, columns and more.
Chimneys - Roof Termination
Chimneys and single wall vents roof termination.
Heat Transmission Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Moisture Transport through Walls and Roofs
Moisture will flow through a building wall or roof if the vapor partial pressure is higher on one of the sides.
Rainfall Draining of Roof Areas and Vertical Downspouts
Capacities of vertical downspouts when draining roof areas in rainfall.
Rainfall on Roofs and Gutter Slopes
Draining of roof areas and recommended gutter slopes
Roofing Materials - Weights
Weight calculator for roofing materials.
Slope Calculator: Convert Between Degrees, Gradient, and Grade
Convert slopes pitch between degrees, gradients and grades.
Walls - No. of Studs
Calculate required number of studs in a wall.
