EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Copper tubes dimensions according EN 12449:
| Nominal Sizes | External Diameter | External Diameter Tolerance | Minimum Wall Thickness | Wall Thickness Tolerance | ||
| DN | mm | inch | mm | mm | mm | mm |
| 10 | 12 | 3/8 | 12 | 0.08 | 1.0 | 0.13 |
| 15 | 15 | 0.08 | 1.0 | 0.13 | ||
| 15 | 18 | 1/2 | 18 | 0.08 | 1.0 | 0.13 |
| 20 | 22 | 3/4 | 22 | 0.12 | 1.0 | 0.13 |
| 25 | 28 | 1 | 28 | 0.12 | 1.5 | 0.13 |
| 32 | 35 | 1 1/4 | 35 | 0.15 | 1.5 | 0.13 |
| 40 | 42 | 1 1/2 | 42 | 0.15 | 1.5 | 0.13 |
| 50 | 54 | 2 | 54 | 0.20 | 2.0 | 0.13 |
| 65 | 76.1 | 2 1/2 | 76.1 | 0.20 | 2.0 | 0.13 |
| 80 | 88.9 | 3 | 88.9 | 0.20 | 2.0 | 0.13 |
| 100 | 108 | 4 | 108 | 0.50 | 2.5 | 0.13 |
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K, L and M - Working Pressures vs. Size
CTS - Copper Tube Sizes - Dimensions used in Plumbing
Copper tube sizes used in plumbing.
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
