ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Dimensions of copper tubes according ASTM B88M Standard Specification for Seamless Copper Water Tube (Metric) are indicated in the table below.
| Nominal Size Outside Diameter (mm) | Wall Thickness (mm) | Tolerance +/- Maximum Deviation at any Point (mm) | Weight (kg/m) |
| 6 | 0.9 | 0.08 | 0.12 |
| 8 | 0.9 | 0.09 | 0.18 |
| 10 | 0.9 | 0.09 | 0.23 |
| 12 | 1.2 | 0.1 | 0.36 |
| 15 | 1.2 | 0.1 | 0.47 |
| 18 | 1.2 | 0.1 | 0.57 |
| 22 | 1.6 | 0.15 | 0.92 |
| 28 | 1.6 | 0.15 | 1.19 |
| 35 | 1.6 | 0.15 | 1.50 |
| 42 | 1.8 | 0.2 | 2.03 |
| 54 | 2.1 | 0.2 | 3.06 |
| 67 | 2.4 | 0.25 | 4.35 |
| 79 | 2.8 | 0.3 | 5.99 |
| 105 | 3.4 | 0.35 | 9.70 |
| 130 | 4.0 | 0.4 | 14.2 |
| 156 | 4.8 | 0.5 | 20.3 |
| 206 | 6.8 | 0.7 | 38.0 |
| 257 | 8.5 | 0.85 | 59.3 |
| 308 | 10.3 | 1 | 86.1 |
| 6 | 0.7 | 0.07 | 0.10 |
| 8 | 0.8 | 0.08 | 0.16 |
| 10 | 0.8 | 0.08 | 0.21 |
| 12 | 0.9 | 0.09 | 0.28 |
| 15 | 1.0 | 0.1 | 0.39 |
| 18 | 1.0 | 0.1 | 0.48 |
| 22 | 1.1 | 0.1 | 0.65 |
| 28 | 1.2 | 0.1 | 0.90 |
| 35 | 1.4 | 0.15 | 1.32 |
| 42 | 1.5 | 0.15 | 1.71 |
| 54 | 1.7 | 0.15 | 2.50 |
| 67 | 2.0 | 0.15 | 3.65 |
| 79 | 2.3 | 0.2 | 4.95 |
| 105 | 2.8 | 0.25 | 8.04 |
| 130 | 3.1 | 0.3 | 11.0 |
| 156 | 3.5 | 0.3 | 15.0 |
| 206 | 5.0 | 0.35 | 28.2 |
| 257 | 6.3 | 0.5 | 44.4 |
| 308 | 7.1 | 0.65 | 60.0 |
| 6 | 0.6 | - | 0.09 |
| 8 | 0.6 | - | 0.13 |
| 10 | 0.6 | - | 0.16 |
| 12 | 0.6 | 0.06 | 0.19 |
| 15 | 0.7 | 0.07 | 0.28 |
| 18 | 0.7 | 0.07 | 0.34 |
| 22 | 0.8 | 0.08 | 0.48 |
| 28 | 0.9 | 0.09 | 0.69 |
| 35 | 1.1 | 0.1 | 1.05 |
| 42 | 1.2 | 0.1 | 1.37 |
| 54 | 1.5 | 0.15 | 2.21 |
| 67 | 1.6 | 0.15 | 2.94 |
| 79 | 1.8 | 0.2 | 3.90 |
| 105 | 2.4 | 0.25 | 6.92 |
| 130 | 2.7 | 0.25 | 9.65 |
| 156 | 3.1 | 0.3 | 13.3 |
| 206 | 4.3 | 0.45 | 24.4 |
| 257 | 5.4 | 0.55 | 38.2 |
| 308 | 6.4 | 0.65 | 54.2 |
- 1 mm = 0.0394 in
The B88M specification covers seamless copper water tube suitable for general plumbing, similar applications for the conveyance of fluids, and commonly used with solder, flared, or compression-type fittings. The type of copper water tube suitable for any particular application is determined by the internal or external fluid pressure, by the installation and service conditions, and by local requirements. Means of joining or bending are also factors that affect the selection of the type of tube to be used.
- Annealed tube is suitable for use with flared or compression fittings, and with solder-type fittings, provided rounding and sizing of the tube ends is performed where needed.
- Drawn temper tube is suitable for use with solder-type fittings. Types A and B tube, in the drawn temper, are suitable for use with certain types and sizes of compression fittings.
This specification is the metric companion of Specification B 88.
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B88 - Seamless Copper Water Tubes - Dimensions
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Nickel and Nickel Alloy Pipes - Temperature Ranges
Temperature ranges for bending nickel and nickel alloy pipes and tubes.
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
