Voltage Sources vs. Current Sources
Voltage Source
  • A voltage source maintains a fixed supply voltage to an electrical circuit - independent of the circuit load resistance and the applied current.
Current Source
  • A current source maintains a fixed supply current through an electric circuit - independent of the circuit load resistance and applied voltage.
Note that real voltage and current sources have limits to the voltage/currents they can provide. A voltage source "prefer" open circuits (no connection between the poles) and current sources "prefer" closed circuits (short cuts).
Electrical
Current Divider - Online Calculator
An electric current divider outputs a current that is a fraction of the input current.
Electric Circuits Voltage Drop
Ohm's law and voltage drop in electric circuits.
Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Parallel Circuits
Electrical Series Circuits
Voltage and current in electrical series circuits.
Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
Voltage Dividers - Online Calculator
Output voltage potential divider.
