Refrigeration Machinery - Required Ventilation
Ventilation required for refrigeration machinery - like compressors - in hot areas:
Air Conditioning Systems
Calculating Cooling Loads
Calculating chiller and cooling tower refrigeration loads - in tons.
Refrigerants - Environmental Properties
Physical and environmental properties of some common refrigerants.
Refrigeration Formulas
Calculate compression work, coefficients of performance and more.
Water Evaporator and Condenser Equations
Air conditioner heat loads and evaporator and condenser water flow rates.
