Cast Iron Flanges - Stud Reference Chart
The studs sizes for cast iron flanges class 125 and 250 are indicated in the tables below. The sizes are for standard facing and standard pressure ratings flange to flange.
Cast Iron Flanges - Class 125
| NPS (in) | No. of Studs | Diameter of Stud (in) | Length of Stud (in) |
| 1/2 | 4 | 1/2 | 2-1/2 |
| 3/4 | 4 | 1/2 | 2-1/2 |
| 1 | 4 | 1/2 | 2-3/4 |
| 1-1/4 | 4 | 1/2 | 2-3/4 |
| 1-1/2 | 4 | 1/2 | 3 |
| 2 | 4 | 5/8 | 3-1/2 |
| 2-1/2 | 4 | 5/8 | 3-3/4 |
| 3 | 4 | 5/8 | 3-3/4 |
| 3-1/2 | 8 | 5/8 | 3-3/4 |
| 4 | 8 | 5/8 | 3-3/4 |
| 5 | 8 | 3/4 | 4 |
| 6 | 8 | 3/4 | 4-1/4 |
| 8 | 8 | 3/4 | 4-1/2 |
| 10 | 12 | 7/8 | 4-3/4 |
| 12 | 12 | 7/8 | 5 |
| 14 | 12 | 1 | 5-1/2 |
| 16 | 16 | 1 | 5-1/2 |
- 1 inch = 25.4 mm
Cast Iron Flanges - Class 250
| 1/2 | 4 | 1/2 | 2-3/4 |
| 3/4 | 4 | 5/8 | 3-1/4 |
| 1 | 4 | 5/8 | 3-1/4 |
| 1-1/4 | 4 | 5/8 | 3-1/2 |
| 1-1/2 | 4 | 5/8 | 3-3/4 |
| 2-1/2 | 8 | 5/8 | 4-1/4 |
| 3 | 8 | 5/8 | 4-1/2 |
| 3-1/2 | 8 | 5/8 | 4-1/2 |
| 4 | 8 | 5/8 | 4-3/4 |
| 5 | 8 | 5/8 | 5 |
| 6 | 12 | 5/8 | 5 |
| 8 | 12 | 7/8 | 5-3/4 |
| 10 | 16 | 1 | 6-1/2 |
| 12 | 16 | 1-1/8 | 7 |
| 14 | 20 | 1-1/8 | 7-1/4 |
| 16 | 20 | 1-1/4 | 7-3/4 |
| 18 | 24 | 1-1/4 | 8 |
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Cast Iron Flanged Pipe Fittings - Working Pressures vs. Temperature
Maximum working pressures for cast iron flanged pipe fittings according ANSI B16.1.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 25
ASME/ANSI B16.1 - 1998 - Cast Iron Pipe Flanges and Flanged Fittings - Class 25 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 250
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Forged Steel Flanges - Stud Charts
Number of studs, diameter and length for ANSI forged steel flanges ranging class 150 to 1500.
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
