Storm-Water Runoff Coefficients vs. Surface
Typical storm-water runoff coefficients for various surfaces:
| Surface | Runoff Coefficient |
| Gardens, lawns, parks | 0.05 - 0.25 |
| Pavements, inferior block | 0.40 - 0.50 |
| Pavements, stone or brick | 0.75 - 0.80 |
| Pavements, asphalt | 0.85 - 0.90 |
| Roads, gravel | 0.15 - 0.30 |
| Roadways, macadamized | 0.25 - 0.60 |
| Roofs | 0.70 - 0.95 |
| Walks, gravel | 0.15 - 0.30 |
• Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Horizontal Drainage Pipe - Required Slopes
Minimum pitch of horizontal drainage pipes.
Horizontal Storm Drain Piping
Capacities of horizontal storm drain piping systems.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Rainfall Draining of Roof Areas and Vertical Downspouts
Capacities of vertical downspouts when draining roof areas in rainfall.
Rainfall on Roofs and Gutter Slopes
Draining of roof areas and recommended gutter slopes
Rainfall Units Converter
Convert between different rainfall or storm-water units
