Horizontal Storm Drain Piping
Recommended size of horizontal storm drains below or above ground can be found in the table below. The drained area may be roofs, paved courtyards or similar.
| Drain pipe diameter | Area to be drained | ||||||
| Slope | |||||||
| mm | inches | 1% | 2% | 4% | |||
| m2 | ft2 | m2 | ft2 | m2 | ft2 | ||
| 80 | 3 | 75 | 820 | 110 | 1180 | 150 | 1620 |
| 100 | 4 | 175 | 1880 | 245 | 2640 | 350 | 3770 |
| 150 | 6 | 495 | 5350 | 700 | 7550 | 995 | 10700 |
| 200 | 8 | 1070 | 11500 | 1515 | 16300 | 2135 | 23000 |
The table is based on a rainfall intensity of 100 mm per hour (4 inches per hour). The anticipated rainfall intensity should always be checked with the local authorities.
• Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
Rainfall Draining of Roof Areas and Vertical Downspouts
Capacities of vertical downspouts when draining roof areas in rainfall.
Rainfall on Roofs and Gutter Slopes
Draining of roof areas and recommended gutter slopes
Rainfall Units Converter
Convert between different rainfall or storm-water units
Slope Calculator: Convert Between Degrees, Gradient, and Grade
Convert slopes pitch between degrees, gradients and grades.
Storm-Water Conductors
Roof drain capacities.
Storm-Water Runoff Coefficients vs. Surface
Storm-water runoff coefficients for various surfaces
