Steel Angles - Unequal Legs
Properties in imperial units of steel angles with unequal legs are indicated below.
| Size (in x in) | Dimensions | Static Parameters | |||||||
| Moment of Inertia | Section Modulus | ||||||||
| Depth h (in) | With w (in) | Thickness s (in) | Sectional Area (in2) | Weight (lbf/ft) | Ix (in4) | Iy (in4) | Wx (in3) | Wy (in3) | |
| 4 x 3 1/2 | 4 | 3 1/2 | 5/8 | 4.3 | 14.7 | 6.37 | 4.52 | 2.35 | 1.84 |
| 4 | 3 1/2 | 1/2 | 3.5 | 11.9 | 5.32 | 3.79 | 1.94 | 1.52 | |
| 4 | 3 1/2 | 7/16 | 3.1 | 10.6 | 4.76 | 3.40 | 1.72 | 1.35 | |
| 4 | 3 1/2 | 3/8 | 2.7 | 9.1 | 4.18 | 2.95 | 1.49 | 1.17 | |
| 4 | 3 1/2 | 5/16 | 2.3 | 7.7 | 3.56 | 2.55 | 1.26 | 0.99 | |
| 4 | 3 1/2 | 1/4 | 1.8 | 6.2 | 2.91 | 2.09 | 1.03 | 0.81 | |
| 4 x 3 | 4 | 3 | 5/8 | 4.0 | 13.6 | 6.03 | 2.87 | 2.30 | 1.35 |
| 4 | 3 | 1/2 | 3.3 | 11.1 | 5.05 | 2.42 | 1.89 | 1.12 | |
| 4 | 3 | 7/16 | 2.9 | 9.8 | 4.52 | 2.18 | 1.68 | 0.99 | |
| 4 | 3 | 3/8 | 2.5 | 8.5 | 3.96 | 1.92 | 1.46 | 0.87 | |
| 4 | 3 | 5/16 | 2.1 | 7.2 | 3.38 | 1.65 | 1.23 | 0.73 | |
| 4 | 3 | 1/4 | 1.7 | 5.8 | 2.77 | 1.36 | 1.00 | 0.60 | |
| 3 1/2 x 3 | 3 1/2 | 3 | 1/2 | 3.0 | 10.2 | 3.45 | 2.33 | 1.45 | 1.10 |
| 3 1/2 | 3 | 7/16 | 2.7 | 9.1 | 3.10 | 2.09 | 1.29 | 0.98 | |
| 3 1/2 | 3 | 3/8 | 2.3 | 7.9 | 2.72 | 1.85 | 1.13 | 0.85 | |
| 3 1/2 | 3 | 5/16 | 1.9 | 6.6 | 2.33 | 1.58 | 0.95 | 0.72 | |
| 3 1/2 | 3 | 1/4 | 1.6 | 5.4 | 1.91 | 1.30 | 0.78 | 0.59 | |
| 3 1/2 x 2 1/2 | 3 1/2 | 2 1/2 | 1/2 | 2.8 | 9.4 | 3.24 | 1.36 | 1.41 | 0.76 |
| 3 1/2 | 2 1/2 | 7/16 | 2.4 | 8.3 | 2.91 | 1.23 | 1.26 | 0.68 | |
| 3 1/2 | 2 1/2 | 3/8 | 2.1 | 7.2 | 2.56 | 1.09 | 1.09 | 0.59 | |
| 3 1/2 | 2 1/2 | 5/16 | 1.8 | 6.1 | 2.19 | 0.94 | 0.93 | 0.50 | |
| 3 1/2 | 2 1/2 | 1/4 | 1.4 | 4.9 | 1.80 | 0.78 | 0.76 | 0.41 | |
| 3 x 2 1/2 | 3 | 2 1/2 | 1/2 | 2.5 | 8.5 | 2.08 | 1.30 | 1.04 | 0.74 |
| 3 | 2 1/2 | 7/16 | 2.2 | 7.6 | 1.88 | 1.18 | 0.93 | 0.66 | |
| 3 | 2 1/2 | 3/8 | 1.9 | 6.6 | 1.66 | 1.04 | 0.81 | 0.58 | |
| 3 | 2 1/2 | 5/16 | 1.6 | 5.6 | 1.42 | 0.90 | 0.69 | 0.49 | |
| 3 | 2 1/2 | 1/4 | 1.3 | 4.5 | 1.17 | 0.75 | 0.56 | 0.40 | |
| 3 | 2 1/2 | 3/16 | 1.0 | 3.4 | 0.91 | 0.58 | 0.43 | 0.31 | |
| 3 x 2 | 3 | 2 | 1/2 | 2.3 | 7.7 | 1.92 | 0.67 | 1.00 | 0.47 |
| 3 | 2 | 7/16 | 2.0 | 6.8 | 1.73 | 0.61 | 0.89 | 0.42 | |
| 3 | 2 | 3/8 | 1.7 | 5.9 | 1.53 | 0.54 | 0.78 | 0.37 | |
| 3 | 2 | 5/16 | 1.5 | 5.0 | 1.32 | 0.74 | 0.66 | 0.32 | |
| 3 | 2 | 1/4 | 1.2 | 4.1 | 1.09 | 0.39 | 0.54 | 0.26 | |
| 3 | 2 | 3/16 | 0.9 | 3.1 | 0.84 | 0.31 | 0.42 | 0.20 | |
| 2 1/2 x 2 | 2 1/2 | 2 | 3/8 | 1.6 | 5.3 | 0.91 | 0.51 | 0.55 | 0.36 |
| 2 1/2 | 2 | 5/16 | 1.3 | 4.5 | 0.79 | 0.45 | 0.47 | 0.31 | |
| 2 1/2 | 2 | 1/4 | 1.1 | 3.6 | 0.65 | 0.37 | 0.38 | 0.25 | |
| 2 1/2 | 2 | 3/16 | 0.8 | 2.8 | 0.51 | 0.29 | 0.29 | 0.20 | |
- 1 cm4 = 10-8 m = 104 mm
- 1 in4 = 4.16×105 mm4 = 41.6 cm4
- 1 cm3 = 10-6 m3 = 103 mm3
The standard method for specifying an angle is L 2 1/2 x 2 x 1/4 - indicating an angle 2 1/2 inches deep and 2 inches wide - and 1/4 inches thick.
• Beams and Columns
American Standard Beams - S Beam
American Standard Steel Channels: Weight, Dimensions & Properties
American Wide Flange Steel Beams (W-Beams) - Dimensions and Properties in Imperial Units
Dimensions, weight, section properties, and essential data of American wide flange steel beams (W-beams) according to the ASTM A6 standard.
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Cantilever Beam Calculations: Formulas, Loads & Deflections
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
HE-A Steel Beams
Square Hollow Structural Sections (HSS) – Sizes, Strength & Specifications
Steel Angles - Equal Legs
