Centrifugal Pumps - Stable and Unstable Flow
For stable head-flow characteristic the differential head - h - progressively falls with increasing flow rate - q.
For unstable head-flow characteristic the differential head - h - rises to a maximum and then progressively falls with increasing flow rate - q.
An unstable pump may start to oscillate between the two possible combinations of head-flow. The flow rate will modulate and the pipeline vibrate.
It is recommended that centrifugal pumps are designed and operated under stable conditions.
• Pumps
Alternating Pumps
Securing a system and achieve equal wear by alternating pumps in parallel.
Centrifugal Pump Standards
International centrifugal pump design and dimension standards.
Centrifugal Pumps
Centrifugal Pumps - Minimum Flow
Minimum continuous flow to prevent flashing in centrifugal pumps.
Pump Head and Pressure: Conversion, Calculations, and Charts
Converting head (ft or m) to pressure (psi or bar, kg/cm2) and vice versa.
Pumps - Classifications
Centrifugal pumps vs. positive displacement pumps.
Pumps - Specific Speed
Characterizing of impeller types in pumps in a unique and coherent manner.
