Electrical Motors - Single Phase 230 V Circuit Wiring
All wiring and electrical connections should comply with the National Electrical Code (NEC) and local codes and practices.
Recommended copper wire gage and transformer size for single phase 230 Volts electrical motors:
| Motor Power (hp) | Transformer Apparent Power (kVA) | Wire Gauge (AWG) | ||||
| Distance from Motor to Transformer (feet) | ||||||
| 100 | 150 | 200 | 300 | 500 | ||
| 1.5 | 3 | 10 | 8 | 8 | 6 | 4 |
| 2 | 3 | 10 | 8 | 8 | 8 | 4 |
| 3 | 5 | 8 | 8 | 8 | 4 | 2 |
| 5 | 7.5 | 6 | 4 | 4 | 2 | 0 |
| 7.5 | 10 | 6 | 4 | 3 | 1 | 0 |
With undersized wire between motor and power source the starting and load carrying capabilities of the motor will be limited.
Apparent Power is the power supplied to the electric circuit - typical from a power supplier to the grid - to cover the real and reactive power consumption in the loads.
• Electrical
AWG - Wire Gauge Sizes: Current Ratings, Charts, Measurements, and Conversion Guide
Amp ratings vs. US AWG wire gauge.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
Electric Motors - 230 & 460V Three Phase Circuits Wiring
Sizing of copper wire and transformers for three phase 230 & 460V electrical motors.
