Drawing Scales
Blueprint drawings are typically drawn in
  • 1:20, 1:50 or 1:100 (SI-units)
or
  • 1/4" or 1/8"  (Imperial units, US)
scales.
SI-Units
To scale a SI-drawing
  • multiply the measurement on the drawing with the denominator
where the denominator is the number after the colon.
Example - Blueprint Drawing Scale 1:50
An actual length of 1 cm is measured on a 1:50 blueprint floor plan. The physical length can be calculated as
(1 cm) 50 = 50 cm
Imperial Units - U.S.
A 1/4" scale means that each 1/4" (inch) on the plan counts for 1' (feet) of actual physical length.
To scale a blueprint in imperial units to actual feet
  • multiply the measurement on the drawing (in inches decimal equivalent) with the denominator
where the denominator is the bottom number.
Example - Blueprint Drawing Scale 1/4"
An actual length is measured to 1-3/8" on a 1/4" blueprint floor plan. The physical length can be calculated as
(1-3/8 inch) 4 = (1.375 inch) 4
= 5.5 feet
= 5' 6"
Commonly Used Drawing Scales
Details
  • 1:1
  • 1:5
  • 1:10
  • 1:20
Component Drawings, Assembly
  • 1:20
  • 1:10
  • 1:5
Floor Plans, General Arrangement (GA)
  • 1:40
  • 1:50
Location Plot Plans
  • 1:80
  • 1:100
  • 1:200
Location Plat Plans
  • 1:500
Block Plan, City Maps and larger
  • 1:1000
  • 1:1250
  • 1:2500
Ordnance Survey Maps
  • 1:100000
  • 1:50000
  • 1:25000
  • 1:10000
Basics
Drawing Tools
2D and 3D engineering drawing tools.
ANSI/ASME Y14.1 - U.S. Standard Engineering Drawing Sizes
US engineering drawing sizes based on ANSI/ASME Y14.1.
Area Survey App
Online app that can be used to make an exact plot of a surveyed area - like a room, a property or any 2D shape.
Blueprint Letters
Letters commonly used to differentiate blueprint drawings.
Builder's to Surveyor's Measurements
Convert builder's measurements to surveyor's measurements.
Building Tolerances
Typical tolerances for floors, walls, columns and more.
Drawings - Sheet Layouts
Standard drawing sheets layouts.
Drawings - Standard Metric Sizes
Standard metric drawing sheet sizes.
Golden Section
Golden Section also called the Golden Mean.
Lengths and Areas vs. Mapping Scales
Convert lengths areas between different mapping scales.
Draw P&ID diagrams online in the browser with Google Docs.
Paper Drafting Sizes - Comparing ISO and U.S. Drawing Sheets
ISO vs. U.S. and Canadian drawing sheets.
Paper Drafting Sizes - ISO 216 series A, B and C
ISO 216 A, B and C drawing series - dimensions of regular, oversized and envelope sheets.
Paper Sizes - commonly used in U.S. Offices
Office paper sizes as Letter, Legal, Tabloid and more.
Paper Sizes - Imperial
Printing and drawing papers sizes.
Scales of Objects
The relative scale of objects.
U.S. Standard Architectural Drawing Sizes
US architectural drawing sizes and formats.
