Pneumatic Cylinder Velocity
Calculating pneumatic cylinder velocity
Velocity of an pneumatic cylinder can be calculated as
s = 28.8 q / A (1)
s = velocity (inches/sec)
q = volume flow (cubic feet/min)
A = piston area (square inches)
s = 28.8 q / A (1)
Add standard and customized parametric components - like flange beams, lumbers, piping, stairs and more - to your Sketchup model with the Engineering ToolBox - SketchUp Extension - enabled for use with the amazing, fun and free SketchUp Make and SketchUp Pro .Add the Engineering ToolBox extension to your SketchUp from the Sketchup Extension Warehouse!
oC
oF
m
km
in
ft
yards
miles
naut miles
m2
km2
in2
ft2
miles2
acres
m3
liters
in3
ft3
us gal
kgf
N
lbf
m/s
km/h
ft/min
ft/s
mph
knots
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
m3/s
m3/h
US gpm
cfm
2 12
