Pressure Loss in Pipes connected in Series or Parallel
Calculate pressure loss in pipes connected in series or parallel.
Pipes in Series
For pipes connected in series the pressure loss is the sum of the individual losses:
dp = dp1 + dp2 + .. + dpn                                   (1)
dp = total pressure loss (Pa, psi)
dp1..n = individual pressure loss in each pipe (Pa, psi)
The mass flow rate is the same in all pipes:
m = m1 = m2 = .... = mn                                 (1b)
m = mass flow (kg/s, lb/s)
Pipes in Parallel
For pipes connected in parallel the pressure loss is the same in all pipes:
dp = dp1 = dp2 = .... = dpn                                    (2)
The total mass flow is the sum of the flow in each pipe:
m = m1 + m2 + .. + mn                                         (2b)
The pressure loss in the equations above can be substituted with a generic expression for pressure loss like the D'Arcy-Weisbach equation.
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 10
