Hot Water Heating System Temperatures vs. Outdoor Temperatures
A hot water heating system is in general designed for a maximum heat load at minimum design outdoor temperature.
The outdoor design temperature used depends on national codes, standards and meteorological data valid for the actual location.
It is common to use an outdoor design temperature that is the statistically lowest temperature for a given period (commonly used are periods of 3 days or similar). Most of the time the outdoor temperature will be significant higher - with a required heat load for the heating system to deliver significant lower - than the maximum designed heat load.
Therefore, most of the year heat emission from radiators and heating elements are reduced by lowering the mean surface temperature of the heating elements by
- reducing the water flow through the radiators, or
- reducing the water temperature to the radiators, or
- both reducing flow and reducing temperature through/to the radiators
Keeping the hot water design temperature constant through the heating season makes the modulating control valves on the heating elements to perform mostly outside their design range. Modulating valves do not perform very well with a reduced flow at nearly closed positions.
By reducing the water temperature at higher outdoor temperatures as shown in the diagram above the modulating valves will operate in their design range with much better performance.
• Heating Systems
Design of Hot Water Heating Systems
Calculate gravity and forced circulating hot water heating systems.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Energy Accumulated in Heated Water - kWh
Heating System Flow Rates
Calculate flow rates in heating systems.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Heating System - Design Procedure
Hot water heating system design procedure with heat loss, boiler rating, heater units and more.
Hot Water Heating System Online Design Application
Hot Water Heating Systems - Flow Temperatures vs. Outside Temperatures
Seasonal effects on hot-water heating systems flow temperatures.
Pressure loss nomogram for hot water steel pipes.
Hot-Water Heating Systems - Classification
Hot-water heating systems can be classified by temperature and pressure.
