Air Duct Components - Minor Dynamic Loss Coefficients
Minor or Dynamic losses in duct systems are pressure losses caused by
- change in air direction from elbows, offsets, and takeoffs
- restrictions or obstructions in the air stream - in/outlet fans, dampers, filters, and coils
- air velocity changes due to changes in duct sizes
Minor or dynamic pressure loss in air duct system components can be expressed as
Δpminor_loss = ξ ρ v2 / 2 (1)
Δpminor_loss = minor pressure loss (Pa (N/m2), psf (lb/ft2))
ρ = density of air (1.2 kg/m3, 2.336×10-3 slugs/ft3)
v = flow velocity (m/s, ft/s)
Minor loss coefficients for different components in air duct distribution systems:
| Component or Fitting | Minor Loss Coefficient - ξ - |
| 90o bend, sharp | 1.3 |
| 90o bend, with vanes | 0.7 |
| 90o bend, rounded radius/diameter duct <1 |
0.5 |
| 90o bend, rounded radius/diameter duct >1 |
0.25 |
| 45o bend, sharp | 0.5 |
| 45o bend, rounded radius/diameter duct <1 |
0.2 |
| 45o bend, rounded radius/diameter duct >1 |
0.05 |
| T, flow to branch (applied to velocity in branch) |
0.3 |
| Flow from duct to room | 1.0 |
| Flow from room to duct | 0.35 |
| Reduction, tapered | 0 |
| Enlargement, abrupt (due to speed before reduction) (v1= velocity before enlargement and v2 = velocity after enlargement) |
(1 - v2/ v1)2 |
| Enlargement, tapered angle < 8o (due to speed before reduction) (v1= velocity before enlargement and v2 = velocity after enlargement) |
0.15 (1 - v2/ v1)2 |
| Enlargement, tapered angle > 8o (due to speed before reduction) (v1= velocity before enlargement and v2 = velocity after enlargement) |
(1 - v2/ v1)2 |
| Grilles, 0.7 ratio free area to total surface | 3 |
| Grilles, 0.6 ratio free area to total surface | 4 |
| Grilles, 0.5 ratio free area to total surface | 6 |
| Grilles, 0.4 ratio free area to total surface | 10 |
| Grilles, 0.3 ratio free area to total surface | 20 |
| Grilles, 0.2 ratio free area to total surface | 50 |
Download and print Air Flow - Minor Loss chart
Example - Minor Loss in a Bend
The minor loss in a 90o sharp bend with minor loss coefficient 1.3 and air velocity 10 m/s can be calculated as
Δpminor_loss = (1.3) (1.2 kg/m3) (10 m/s)2 / 2
= 78 N/m2, Pa
• Ventilation Systems
Air Ducts - Minor Loss Coefficient Diagrams
Minor loss coefficient diagrams for air ductwork, bends, expansions, inlets and outletsĀ - SI units.
Air Ducts - Sizing
Required duct area vs. air flow.
Air Ducts - Velocity Diagram
Air flow volume, duct size, velocity and dynamic pressure.
The equal friction method for sizing air ducts is easy and straightforward to use.
Ductwork - Seal Classes
Ductwork air leakage classes.
Equivalent Length vs. Minor Pressure Head Loss in Pipe and Duct Components
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Pipe and Tube System Components - Minor (Dynamic) Loss Coefficients
Minor loss coefficients for components used in pipe and tube systems.
Ventilation Components - Minor Pressure Loss
Pressure loss in ventilation system components like dampers, filters, heaters, coolers and more.
