The latent heat of fusion of a substance is
- the amount of heat required to convert a unit mass of the solid into liquid without change in temperature
The latent heat of melting for some common solids are indicated below:
| Product | Latent Heat of Melting |
| (kJ/kg) | |
| Acetic acid | 181 |
| Acetone | 98.3 |
| Alcohol, ethyl (ethanol) | 108 |
| Alcohol, methyl (methanol) | 98.8 |
| Alcohol, propyl | 86.5 |
| Aluminum | 396 |
| Ammonia | 339 |
| Aniline | 113.5 |
| Antimony | 161 |
| Benzene | 126 |
| Bismuth | 52.2 |
| Brass | 168 |
| Bromine | 66.7 |
| Cadmium | 56 |
| Carbon disulfide | 57.6 |
| Carbon dioxide | 184 |
| Carbon tetrachloride | 174 |
| Cast iron | 126 |
| Chloroform | 77 |
| Chromium | 394 |
| Cobalt | 275 |
| Copper | 206 |
| Decane | 201 |
| Dodecane | 216 |
| Ether | 96.2 |
| Ethyl ether | 113 |
| Ethylene glycol | 181 |
| Glycerine | 200 |
| Gold | 63 |
| Heptane | 140 |
| Hexane | 152 |
| Ice, see Water | |
| Iodine | 62.2 |
| Iron, gray cast | 96 |
| Iron, white cast | 138 |
| Iron, slag | 209 |
| Lead | 23 |
| Manganese | 240 |
| Mercury | 11.4 |
| Naphthaline | 151 |
| Nickel | 293 |
| Octane | 181 |
| Paraffin | 147 |
| Phenol | 121 |
| Phosphrus | 21.1 |
| Platinium | 103 |
| Potassium | 59 |
| Propane | 79.9 |
| Propylene | 71.4 |
| Silver | 105 |
| Sulphur | 39.2 |
| Tin | 59 |
| Toluene | 71.8 |
| Water, Ice | 334 |
| Wood's alloy | 33.5 |
| Zinc | 112 |
- 1 kJ/kg = 0.4299 Btu/lbm = 0.23884 kcal/kg
Heat Required to Melt a Solid
The heat required to melt a solid can be calculated as
q = Lm m (1)
q = required heat (J, Btu)
Lm = latent heat of melting (J/kg, Btu/lb)
m = mass of substance (kg, lb)
Example - Required Heat to melt Ice to Water
The heat required to melt 10 kg of ice to water can be calculated as
q = Lm m
= (334×103 J/kg) (10 kg)
= 3340000 J
= 3340 kJ
• Melting and Freezing Points
• Thermodynamics
Aluminum Alloys - Mechanical Properties
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Iron Binary Eutectic Alloys - Melting Points
Fe - Iron - binary eutectic alloys and melting points.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Metal Alloys - Melting Points
Alloys and their melting points.
Metals - Boiling Points and Specific Heat
Boiling points and specific heat of liquid metals.
Snow Melting Systems
Sizing snow melting systems - water and antifreeze.
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
