ISO - International Organization for Standardization
ISO - the International Organization for Standardization.
ISO - the International Organization for Standardization - is an international standard setting body made up of representatives from national standards bodies.
ISO is intended to standardise technical rules worldwide, thus simplifying the exchange of goods and removing trade barriers.
For the world's largest developer of standards the principal activity is development of technical and economical standards and the ISO Standards cover a wide variety of items ranging from medical equipment to shipbuilding:
  • Mechanical
  • Machinery
  • Chemistry
  • Coatings
  • Construction
  • Metals
  • Aerospace
  • Fuels
  • Energy
  • Transportation
  • Information
  • Image Technology
  • Quality
  • Measurements
  • Safety
  • Environment
  • Medical
  • Consumer Goods
ISO Numbers and Names
ISO standards are numbered with the format:
"ISO nnnnn:yyyy: Title"
"nnnnn" = standard number
"yyyy" = year published
"Title" = description of the subject
In addition may European and Domestic versions be publishes as:
EN ISO nnnnn = European version of the International Standard
BS EN ISO nnnnn = British version of the European version of the International Standard
Example ISO number
ISO IS228-1:2000: Pipe threads where pressure-tight joints are not made on the threads -- Part 1: Dimensions, tolerances and designation
ISO also creates Technical Reports such as references, explanations, etc, where "TR" replace "IS" in the standard's name.
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 30
