Hooke's Law
Hooke's law - force, elongation and spring constant.
The force required to extend or compress a spring can be expressed with Hooke's Law as
F = - k s                                    (1)
F = force (N)
k  = spring constant (N/m)
s = extension or compression distance (m)
Example - Car Suspension
The maximum compression of a car suspension with mass 2000 kg (500 kg on each wheel) shall not exceed 0.1 m.
The force acting on each spring can be calculated using Newton's Second Law
F = (500 kg) (9.81 m/s2)
   = 4905 N
   = 4.9 kN
The required spring constant for the suspension can be calculated with (1) as
k = - F / s
  = - (4905 N) / (- 0.1 m)
  = 49050 N/m
  = 49 kN/m
Note that this is the value for the static load of the car. You may probably at least double the value for handling dynamic forces, potholes and similar.
Hook's Law of Elasticity
In the generalized variation of Hooke's law it states that the strain/deformation of an elastic object or material is proportional to the stress applied to it. It may be expressed mathematically as
σ = E ε                              (2)
σ = stress (Pa)
E = Young's Modulus of Elasticity (Pa)
ε = strain (m/m)
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 10
