Hardwood Lumber - Dimensions
Dimensional lumber made from hardwood varies from the sizes used for softwood. Hardwood lumber dimensional sizes are indicated below:
| Rough Size | Nominal Size | Actual Dimension (in) | |
| (Inches) | (Fraction In) ("quarter") | S1S1) | S2S2) |
| 3/8 | 3/16 (4.8 mm) | ||
| 1/2 | 3/8 (9.5 mm) | 5/16 (7.9 mm) | |
| 5/8 | 1/2 (13 mm) | 7/16 (11 mm) | |
| 3/4 | 5/8 (16 mm) | 9/16 (14 mm) | |
| 1 | 4/4 | 7/8 (22 mm) | 13/16 (21 mm) |
| 1 1/4 | 5/4 | 1 1/8 (29 mm) | 1 1/16 (27 mm) |
| 1 1/2 | 6/4 | 1 3/8 (35 mm) | 1 5/16 (33 mm) |
| 1 3/4 | 1 1/2 (38 mm) | ||
| 2 | 8/4 | 1 13/16 (46 mm) | 1 3/4 (44 mm) |
| 3 | 12/4 | 2 13/16 (71 mm) | 2 3/4 (70 mm) |
| 3 1/2 | 3 1/4 (83 mm) | ||
| 4 | 16/4 | 3 13/16 (97 mm) | 3 3/4 (95 mm) |
- 1 inch = 25.4 mm
1) S1S - Surfaced one Side
2) S2S - Surfaced two Sides
Common Hardwood Species
- Oak
- Walnut
- Basswood
- Beech
- Birch
- Butternut
- Chestnut
- Cherry
- Elm
- Gum
- Hickory
- Maple
- Mahogany
- Yellow Poplar
Hardwood Grades
- FAS - First and Second
- best grade - required for a natural or stained finish
- at least 6 inches wide and 8 to 16 feet long
- 83.3% clear wood on the worst face
- Select - No. 1 Common
- minimum 3 inches wide and 4 - 16 feet long
- 66.6% clear wood on the worst face
- Select - No. 2 Common
- Select - No. 3 Common
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Density of Wood Species: Data & Material Guide
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Headers - Max. Supported Weight
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
