Fasteners - Type Chart
Wood screws, machine screws, sheet metal screws, self drilling SMS and more.
Fastener Categories
  • Wood Screws, Machine Screws, Sheet Metal Screws, Self Drilling SMS, Hex Bolts, Carriage Bolts, Lag Bolts, Set Screws, Socket Screws, Eye Bolts, Eye Lags, U-Bolts, J-Bolts, Hanger Bolts
Head Styles
  • Flat, Oval, Pan, Truss, Round, Hex, Hex Washer, Slotted Hex Washer, Socket Cap, Button
Drive Types
  • Phillips and Frearson, Slotted, Combination, Socket, Hex, Allen
Nut Types
  • Hex, Nylon Insert Lock, Jam, Nylon Insert Jam Lock, Wing, Cap, Acorn, Flange, Tee, Square, Prevailing Torque Lock, K-Lock or Keep, Coupling
Washer Types
  • Flat, Fender, Finishing, Split Lock, External Toot Lock, Internal Toot Lock, Square, Dock, Ogee
http://www.boltdepot.com/fastener-information/Printable-Tools/Type-Chart.pdf
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 30
