Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity.
Evaporation temperatures, condensing temperatures and average compressor capacities are indicated in the chart below:
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 30
