Elastomers Properties
Typical operating temperature-ranges for elastomers:
| ID (DIN ISO 1629) | Name | Characterized by | Typical Applicatons | Typical Operationg Temperature Range (oC) |
| ACM | polyacrylic rubber | good hot-air resistance good ozon and weather resistance good resistance to lubricating oils with additives low elasticity medium strength |
oil seals higher temperature seals |
-20 - 150 |
| AEM | ethylene acrylate rubber | good mechanical properties temperature resistant good compression ratio | oil seals higher temperature seals |
-40 - 160 |
| CR | chloroprene rubber | good weather, ozone, aging and chemical resistance high flame retardance good mechanical properties abrasion resistance flexible in low temperatures |
refrigerant sealings outdoor seals adhesives or glues |
-35 - 90 |
| ECO | epichlorohydrin rubber | resistant to engine oil and fuels very low gas permeability weather and ozone resistant low compression ratio |
in engine bearings vibration dampers fuel lines |
-40 - 120 |
| EPDM | ethylene propylene dietene rubber | high elasticity weather resistant good heat, ozzone and aging resistance good low-temperature performance |
parts in contact with brake fluids, cooling water, refrigerants | -40 - 150 |
| FKM | fluorine rubber | good resistance to oils, fuels and aggressive media very good aging, ozone and weather resistancy low gas permeability | fuel applications | -20 - 200 |
| FVMQ | fluorosilicone rubber | very good chemical resistance to hydrocarbons, mineral oils and fuel | -55 - 175 | |
| HNBR | hydrogenated nitrile butadiene rubber | properties comparable to NBR with higher operating temperatures | parts in contact with mineral oil, diesel and cooling water | -30 - 140 |
| IIR | isobutene-isoprene rubber | very low permeability to air, water vapor and gases good weather, ozone, organic and inorganic chemicals and aging resistance |
tires | -40 - 110 |
| NBR | nitrile butadiene rubber | oil resistant (depends on acrylonitrile content) good mechanical propertties good abrasion resitance |
mineral oil and grease seals | -30 - 100 |
| PUR | polyurehanes | properties varies with widely with the chemical recepie - typical very good low temperature flexibility, good recovery performance, low gas permeability, good mineral oil resistance and high strength | adhesives or glues parts like seat cushions, exterior elements in cars soundproofing suspension insulators |
-50 - 110 |
| SBR | styrene butadiene rubber | very good mechanical properties abrasian resistance |
tires v-belts |
-40 - 110 |
| VMQ | silicone rubber | high thermal resistance very flexible at low temperatures resistant to oils and water vapor good weather resistance good dielectric properties hydrophobic |
seals in electric applications, radiators | -50 - 200 |
Elastomers
Natural and syntetic rubbers guide.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Rubbers and Elastomers - Chemical Resistance
Rsistance to chemicals - solvents and softeners - swelling properties.
