Present Value
The value of money in the future is the Present Value.
The value of money in the future can be calculated to Present Value or Present Worth with the "discount rate" as
P = F / (1 + i)n         (1)
F = future cash flow (positive for receipts, negative for disbursements)
P = present value
i = discount rate
n = number of interest periods
The factor "1 / (1 + i)n" is known as the "single payment present worth factor".
Present Value - Online Calculator
F - single future cash flow
i - discount rate (%)
n - number of periods
Load Calculator!
Example - Present Value
The present value of a future cash flow of 7 in period 10 with discount rate 5% (i = 0.05) can be calculated as
P = (7) / (1 + 0.05)10
    = 4.30
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 10
