Conservation of Mass
The Law of Conservation of Mass states that mass can neither be created or destroyed.
The Law of Mass Conservation states that
"mass can neither be created nor destroyed"
The inflows, outflows and change in storage of mass in a system must be in balance.
The mass flow in and out of a control volume (through a physical or virtual boundary) can for an limited increment of time be expressed as:
dM = ρi vi Ai dt - ρo vo Ao dt                            (1)
dM = change of storage mass in the system (kg)
ρ = density (kg/m3)
v = speed (m/s)
A = area (m2)
dt = an increment of time (s)
If the outflow is higher than the inflow - the change of mass dM is negative -
  • the mass of the system decreases
And obvious - the mass in a system increase if the inflow is higher than the outflow.
The Law of Mass Conservation is fundamental in fluid mechanics and a basis for the Equation of Continuity and the Bernoulli Equation.
Example - Law of Mass Conservation
Water with density 1000 kg/m3 flows into a tank through a pipe with inside diameter 50 mm. The velocity of the fluid in the pipe is 2 m/s. The water flows out of the tank through a pipe with inside diameter 30 mm with a velocity of 2.5 m/s.
Using equation (1) the change in the tank content after 20 minutes can calculated as:
dM = (1000 kg/m3) (2 m/s) (3.14 (0.05 m)2 / 4) ((20 min) (60 s/min))
                - (1000 kg/m3) (2.5 m/s) (3.14 (0.03 m)2 / 4) ((20 min) (60 s/min))
    = 2591 kg
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 10
