Concrete Footing
Estimating concrete continous footing.
Concrete required for continous footing can be estmimated with the diagrams below:
oC
oF
m
km
in
ft
yards
miles
naut miles
m2
km2
in2
ft2
miles2
acres
m3
liters
in3
ft3
us gal
kgf
N
lbf
m/s
km/h
ft/min
ft/s
mph
knots
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
m3/s
m3/h
US gpm
cfm
3 30
