Universal Gravitational Law
The gravitational attraction between two objects depends upon the mass of the objects and the distance between them. This relationship is often called the "Universal Law of Gravitation" and can be expressed as
F = kG m1 m2 / r2                               (1)
F = gravitational force (N)
kG = 6.668×10-11 (Nm2/kg2) = the Universal Gravitation Constant
m = mass of object (kg)
r = distance between objects (m)
Example - The Gravitational Force (Weight) Acting on a Person on Earth's Surface
The gravitational force (or weight) acting on a person with mass 70 kg on the earth's surface (6.37×106 m from the earth's center) can be calculated as
F = (6.668×10-11 Nm2/kg2) (5.98×1024 kg) (70 kg) / (6.37×106 m)2
= 688.1 (N)
  • 5.98×1024 (kg) = mass of earth
Dynamics
Mechanics
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Acceleration of Gravity vs. Latitude and Elevation
Acceleration of gravity due to latitude and elevation above sea level.
Center of Gravity
A body and the center of gravity.
Stability - the center of gravity vs. the center of buoyancy.
Mass vs Weight
