Pumps - Suction Head vs. Altitude
Practical pump suction head of a water pump is affected by altitude:
| Elevation above Sea Level | Pressure | Practical Suction Lift | ||||
| (ft) | (m) | (psig) | (ft H2O) | (bar) | (ft H2O) | (m H2O) |
| 0* | 0* | 14.71 | 33.95 | 1 | 22 | 6.7 |
| 1320 | 402 | 14.02 | 32.38 | 0.97 | 21 | 6.4 |
| 2640 | 805 | 13.33 | 30.79 | 0.92 | 20 | 6.1 |
| 3960 | 1207 | 12.66 | 29.24 | 0.87 | 18 | 5.5 |
| 5280 | 1609 | 12.02 | 27.76 | 0.83 | 17 | 5.2 |
| 6600 | 2012 | 11.42 | 26.38 | 0.79 | 16 | 4.9 |
| 7920 | 2414 | 10.88 | 24.13 | 0.75 | 15 | 4.6 |
| 10560 | 3219 | 9.88 | 22.82 | 0.68 | 14 | 4.3 |
* Sea Level
• Pumps
Centrifugal Pumps
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Positive Displacement Pumps
Introduction tutorial to positive displacement pumps basic operating principles.
Pressure to Head Unit Converter
Pressure vs. head units - like lb/in2, atm, inches mercury, bars, Pa and more.
Pumps - NPSH (Net Positive Suction Head)
An introduction to pumps and the Net Positive Suction Head (NPSH).
Static Pressure vs. Head
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
