Pipe Lengths
Pipe is supplied and referred to lengths as
  • single random
  • double random
  • longer than double random
  • cut lengths
Single Random Length
Single random pipe length is usually 18 - 25 feet plain end or 18 - 22 feet threaded and coupled pipes.
Double Random Lengths
Double random length pipes are made between 38 - 40 feet.
Longer than Double Random
The length of longer than double random pipes are more than 38 - 40 feet.
Cut Lengths
Cut length pipes are made in fixed lengths within +/- 1/8 inch. Some pipes are available in about 80 ft lengths.
  • 1 ft (foot) = 0.3048 m
Dimensions of Pipes and Tubes
Equivalent Length Method - Minor Pressure Loss in Piping Systems
Calculate minor pressure loss in piping systems with the Equivalent Pipe Length Method.
