Pendulum
A simple pendulum oscillates in the vertical plane due to gravity.
A simple - or mathematical - pendulum consists of a rigid body suspended from a fixed horizontal axis about which the body may oscillate in a vertical plane due to the action of gravity.
The oscillating period for a simple pendulum can be calculated as
T = 2 π (l / ag)1/2              (1)
T = oscillating period for one cycle (s)
l = length of the pendulum (m, ft)
ag = acceleration of gravity (9.81 m/s2, 32.17 ft/s2)
Example - Calculate the length of a pendulum with an oscillating period of 1 sec, 10 sec and 100 sec
The length of a pendulum with a given oscillating period can be calculated by transforming (1) to:
l = (T / (2 π))2 ag
Length for 1 sec - typically for an old fashion pendulum clock:
l = ((1 s) / (2 π))2 (9.81 m/s2)
  = 0.249 (m)
Pendulum clocks were the world standard for accurate timekeeping for 270 years until the quartz clock was invented in 1927.
Length for 10 sec:
l = ((10 s) / (2 π))2 (9.81 m/s2)
  = 24.9 (m)
Length for 100 sec:
l = ((100 s) / (2 π))2 (9.81 m/s2)
  = 2487 (m)
Four Types Of Pendulums
It is common to differentiate between four types of pendulums:
  1. Compound or Physical Pendulum - A rigid body suspended from a fixed horizontal axis. The body may oscillate in a vertical plane due to the action of gravity.
  2. Simple or Mathematical Pendulum - Similar to the compound or physical pendulum but the mass is concentrated in a single point and oscillates back and forth in the vertical plane. The mass point is connected to a horizontal axis with a weightless chord.
  3. Conical Pendulum - Similar to the simple pendulum except that the weight suspended by the chord moves in uniform speed around the circumference of a circle in the horizontal plane.
  4. Torsional Pendulum - A disk fixed to a slender rod. The rod is fastened to a fixed frame. If the disk is twisted it will oscillate back and forth about the axis of the rod.
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 30
