Noise Criterion - NC - Online Calculator
An online Noise Criterion - NC - Calculator
The calculator below can used to calculate the NC - Noise Criterion:
Sound Pressure Level (dB) - Octave band mid-frequency (Hz)
63 Hz (upper limit 83 dB)
125 Hz (upper limit 79 dB)
250 Hz (upper limit 75 dB)
500 Hz (upper limit 72 dB)
1000 Hz (upper limit 71 dB)
2000 Hz (upper limit 70 dB)
4000 Hz (upper limit 69 dB)
8000 Hz (upper limit 68 dB)
Load Calculator!
The NC-diagram with the default values from above:
Share
Add standard and customized parametric components - like flange beams, lumbers, piping, stairs and more - to your Sketchup model with the Engineering ToolBox - SketchUp Extension - enabled for use with the amazing, fun and free SketchUp Make and SketchUp Pro .Add the Engineering ToolBox extension to your SketchUp from the Sketchup Extension Warehouse!
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
10 4
