Inflation Rate
Future value of money vs. inflation.
  • An inflation with rising prices will decrease the value of money over time
  • A deflation - the opposite of inflation or negative inflation - with decreasing prices will increase the value of money over time
Inflation Rate
The future value of money after periods with uniform inflation rates can be expressed as
F = P (1 - i)n          (1)
F = future value
P = present value
i = average inflation (or deflation) rate per period (positive for inflation, negative for deflation)
n = number of periods
Example - Inflation and Future Value
The future value of an amount of 100 after 10 periods and 4% of inflation rate can be calculated as
F = 100 (1 - 0.04)10 =
    = 66.5
Future Value of Present Money due to Inflation Rate - Calculator Table
This calculated table visualizes the decrease in future value of present money due to inflation rate and time.
Present Value of Money
Start Year
End Year
Max. Inflation Rate (%)
Load Calculator!
Download and print Inflation chart - Future Value vs. Present Value and Inflation Rate
Variable Inflation Rate
The future value of money after periods with variable inflation rates can be calculated as
F = P (1 - i1) (1 - i2) ...... (1 - in)                  (2)
i1..n = inflation rates of terms
The average inflation rate for all periods can be calculated as
(1 - ia)n = (1 - i1) (1 - i2) ...... (1 - in)                (3)
or
ia = 1 - [(1 - i1) (1 - i2) ...... (1 - in)]1/n                    (3b)
ia = average inflation rate
Share
Topics
Unit Converters
Temperature
oC
oF
Load Calculator!
Length
m
km
in
ft
yards
miles
naut miles
Load Calculator!
Area
m2
km2
in2
ft2
miles2
acres
Load Calculator!
Volume
m3
liters
in3
ft3
us gal
Load Calculator!
Weight
kgf
N
lbf
Load Calculator!
Velocity
m/s
km/h
ft/min
ft/s
mph
knots
Load Calculator!
Pressure
Pa (N/m2)
bar
mm H2O
kg/cm2
psi
inches H2O
Load Calculator!
Flow
m3/s
m3/h
US gpm
cfm
Load Calculator!
3 10
