Fiberglass Pipes and Temperature Limits
Fiberglass pipes and recommended operational temperature ranges:
  • Epoxy glass fiber reinforced pipe: -29 to 149 oC (-20 to 300o F)
  • Vinyl Ester glass fiber reinforced pipe: -29 to 93 oC (-20 to 200 oF)
  • Furan glass fiber reinforced pipe: -29 to 93 oC (-20 to 200 oF)
  • Furan carbon fiber reinforced pipe: -29 to 93 oC (-20 to 200 oF)
  • Phenolic glass fiber reinforced pipe: -29 to 149 oC (-20 to 300 oF)
  • Polyster glass fiber reinforced pipe: -29 to 93 oC (-20 to 200 oF)
Dimensions
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Epoxy Pipes - Support Spacing
Support spacing for reinforced Epoxy fiberglass pipes.
Fiberglass Pipes - common Standards
Commonly used standards for fiberglass pipes and their applications.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
