Carbon and Stainless Steel Flanges - ASME/ANSI Class 600
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 600 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts for Weld neck, Threaded, Slip-on, Lap joint, Socket weld and Blind flanges.
Carbon and stainless steel qualities according ASME B16.5 Table 1A.
| Pipe Size (inches) | Flange Outside Diameter (inches) | Pipe Outside Diameter (inches) | Number of Bolt Holes | Bolt Hole Diameter (inches) 1) | Bolt Circle (inches) |
| 1/2 | 3-3/4 | 0.84 | 4 | 5/8 | 2-5/8 |
| 3/4 | 4-5/8 | 1.05 | 4 | 3/4 | 3-1/4 |
| 1 | 4-7/8 | 1.32 | 4 | 3/4 | 3-1/2 |
| 1-1/4 | 5-1/4 | 1.66 | 4 | 3/4 | 3-7/8 |
| 1-1/2 | 6-1/8 | 1.90 | 4 | 7/8 | 4-1/2 |
| 2 | 6-1/2 | 2.38 | 8 | 3/4 | 5 |
| 2-1/2 | 7-1/2 | 2.88 | 8 | 7/8 | 5-7/8 |
| 3 | 8-1/4 | 3.50 | 8 | 7/8 | 6-5/8 |
| 3-1/2 | 9 | 4.00 | 8 | 1 | 7-1/4 |
| 4 | 10-3/4 | 4.50 | 8 | 1 | 8-1/2 |
| 5 | 13 | 5.56 | 8 | 1-1/4 | 10-1/2 |
| 6 | 14 | 6.63 | 12 | 1-1/4 | 11-1/2 |
| 8 | 16-1/2 | 8.63 | 12 | 1-1/4 | 13-3/4 |
| 10 | 20 | 10.75 | 16 | 1-3/8 | 17 |
| 12 | 22 | 12.75 | 20 | 1-3/8 | 19-1/4 |
| 14 | 23-3/4 | 14.00 | 20 | 1-1/2 | 20-3/4 |
| 16 | 27 | 16.00 | 20 | 1-5/8 | 23-3/4 |
| 18 | 29-1/4 | 18.00 | 20 | 1-3/4 | 25-3/4 |
| 20 | 32 | 20.00 | 24 | 1-3/4 | 28-1/2 |
| 24 | 37 | 24.00 | 24 | 2 | 33 |
1) Recommended bolts are 1/8 smaller than the nominal bolt hole diameters shown.
- 1 inch = 25.4 mm
• Piping Systems
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 1500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 1500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 2500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 2500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 900
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 900 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
